Author Topic: Too Much Trail?  (Read 804 times)
Offline Ellz10
  • ZZ
  • Knowledge is Power
Too Much Trail?
« on: June 11, 2022, 03:39:00 pm »
I need to know if 4.54" of trail is too much to keep me from handling well in the corners.
1977 Honda CB750K with a 2019 GSX-R 600 front end conversion with 45mm offset triples, and a 120/70-18 tire
I could use a 120/60-18 to bring the trail down to 4.29", but I'm not too keen on a 60 in front.
Thoughts on if 4.54" is too much or should be okay?
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
Re: Too Much Trail?
« Reply #1 on: June 11, 2022, 07:06:27 pm »
I run 6-8” of trail. Going around curves at speed is a breeze! I countershift my body weight at lower speeds to make due. Just build it the way you want it and learn how to ride it!
Re: Too Much Trail?
« Reply #2 on: June 11, 2022, 10:44:35 pm »
Yep, even the best handling bikes don't ride themselves.
Re: Too Much Trail?
« Reply #3 on: June 12, 2022, 10:08:10 am »
It's a safe trail number, 115mm. Originally, my racebike was 88.75mm and I eventually destroyed it in what started as a tank slapper.  Now at 99mm and all is well!
Offline Ellz10
  • ZZ
Re: Too Much Trail?
« Reply #4 on: June 12, 2022, 04:32:40 pm »
Oh wow! That seems a bit!Ike you said, I'll just learn how to ride it!
I'm curious, did you do a front end conversion (CBR, GSX-R, ect)? If so, do you use a stabilizer?
Well there's bound to be a learning curve! I'll learn one way or the other!
Sounds good! I might end up going with a 40mm fixed offset retro triple, instead of the 45mm, and it'll kick my trail to about 4.76" (120.9mm). I probably won't need a stabilizer at that point.
But then again I might just stick to 45mm. Good Lord, I just don't know which, hah! If the triples weren't $900 I would just get both!
« Last Edit: June 12, 2022, 04:36:56 pm by Ellz10 »
