« Reply #17 on: June 23, 2022, 08:46:46 AM »
What is od of spacer and O ring ?
The o-ring was about 12.4 mm which was a little big, but all i had at work. The spacer I made at 11.8mm. I cut a 45 degree chamfer on the side that presses against the seal. I believe the bore in the countershaft is 12mm, but i didn't accurately measure it.
I went for a ride last night and left it on the side stand. I guess i will see tonight if it leaked.
Sent from my LG-M703 using Tapatalk
So you put the oring in 1st to the center bore then your milled spacer on the end of the adjuster shaft?
Logged
