Author Topic: How to get it out  (Read 806 times)
How to get it out
« on: June 20, 2022, 06:24:57 AM »
This is swingarm for Dorothy but it came from Suzuki or some other bike.  It seems like it had needle bearings originally, there is only a steel sleeve left now.
The big question is: "How to get it out?"
Re: How to get it out
« Reply #1 on: June 20, 2022, 07:47:54 AM »
Does it go all the way through?  If no, use a long drift punch to knock it out.  If yes, cut out a 1/2" piece with a dremal and then know it out.
Online Don R
« Reply #2 on: June 20, 2022, 07:51:15 AM »
  Slice it in two or three places with a sawzall or hacksaw blade. The big question is what to do then?
« Reply #3 on: June 20, 2022, 07:53:12 AM »
Maybe apply heat to loosen any potential locktite that may have been used.
Offline Kelly E
  • Geriatric Hooligan
« Reply #4 on: June 20, 2022, 10:07:14 AM »
I use 3 double D washers. Drop the washers in and turn them so they sit on top of the bushing/bearing shell. Then it's easy to drive them out with a drift from the other end.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #5 on: June 20, 2022, 02:54:04 PM »
I am curious to see a picture of the whole swingarm.  Could you post one?  Might be able to help identify it and know what is supposed to be in there...
Offline Scootch
  • Someday I'll know what I needed to know years ago
« Reply #6 on: June 20, 2022, 05:37:48 PM »
Maybe talk to a machine shop. They might have some ideas.
Offline Kevnz
« Reply #7 on: June 20, 2022, 10:20:51 PM »
I had to cut my swingarm out of the frame with  a hacksaw as the whole thing was seized in there. ( Kawa KL250) Took the swingarm to an engineering shop; they had to use heat and a 50 ton press! $60 well spent.
Good grammar: The difference between knowing your #$%* and knowing you're #$%*
« Reply #8 on: June 21, 2022, 05:56:27 AM »
Thank you, gents.  Will try one suggestion after another :)
Full picture later today.
« Reply #9 on: June 22, 2022, 06:29:41 AM »
Did not try anthing with the arm yet, still messing with the sidecar.  Anyway, full picture.
« Reply #10 on: June 22, 2022, 07:53:51 AM »
cool, so that was from 82 GS1100e Suzuki, probably lots of other years with same
Online newday777
« Reply #11 on: June 22, 2022, 10:01:37 AM »
How does it size up to the 750 swing arm? Have you had it on already or just preparing to?
« Reply #12 on: June 22, 2022, 12:54:42 PM »
It has to be shortened.
« Reply #13 on: June 22, 2022, 05:03:21 PM »
I use a jigsaw with [fresh] metal-cutting blade to cut a slot in the bushing. This weakens its grip inside the tube and lets me tap (bang?) it out from the opposite side(s).
