She's giving me more head scratches
I had 2 very good rides after the carb adjustments, however on the last ride I blew the main fuse. No problem, I had a spare, changed it and I was able to get home with no further issues. I knew there was a loose cable from the buzzer in the headlight, figured that might created a short.
2 days later I wanted to go for another ride, since she drove beautifuly the ride before I wasn't expecting issues, however she was down on power, lagging when I opened the throttle. So after 2 kilometer I returned home and started checking for issues.
Cylinder 2 was cold. Spark? Yes! Fuel? Yes (spark plug is wet).
I've let the cylinder dry out a bit and tried several hours later with 4 new plugs. 2 still doesn't ignite. However I have spark and fuel (again spark plug was wet). I also blew compressed our into the main jet just to be sure nothing was clogged up.
Timing is good (wasnt changed either after the last ride).
Compression (measured cold with throttle open, still new rings on the pistons as well, only has run 500km)
1: 140
2: 120
3: 125
4: 140
Never had issues before on cyl 2.
Coils are good (new) and I have spark on cyl 2. Same issue when I change lead cables from cyl 2 and 3... Cyl 2 remains cold.
Ideas are appreciated.
Verstuurd vanaf mijn SM-A525F met Tapatalk
