Author Topic: 1971 Engine Mounting Kit?  (Read 581 times)
Offline God of Thunder
  • Trained to reign as the one!
« on: June 28, 2022, 08:41:29 PM »
Hi everyone! I've finally got an engine for my 1971 (go me!). However, I need the bolts to mount it and I'm having a devil of a time finding exactly what I need. Does anyone have a URL of where I can buy like a kit of the bolts to mount it?
1970 CB750K1
1976 CB750K6
Re: 1971 Engine Mounting Kit?
« Reply #1 on: June 29, 2022, 12:14:49 AM »
I've not seen a kit offered of the engine mounting bolts.
You have to buy them individually.
You say It is for your 1971...... What bike is your 1971????
Not a good thing to make us ASSUME what your 71 is.
« Reply #2 on: June 29, 2022, 04:55:43 AM »
His sig says he has 3 different 750's. Either put an add in the wanted section for the bolts you need or start trolling E-bay or any other place where you can locate some used parts. Do you still have the triangle shaped motor mount that goes on the front as you will need that also.
« Last Edit: June 29, 2022, 07:12:44 AM by ekpent »
« Reply #3 on: June 29, 2022, 07:06:39 AM »
This parts fiche shows what "engine hangers" you will need.  I've sourced the short bolts at my local hardware store, but as Eric suggested, the others can be had either from members here or on eBay...
https://www.partzilla.com/catalog/honda/motorcycle/1976/cb750k-a-750-four/frame
Tip: use the part number from the fiche to search on ebay...
https://www.ebay.com/itm/304545342048?epid=1728859038&hash=item46e8512260:g:V6IAAOSwvOhiuTzn
« Reply #4 on: June 29, 2022, 09:55:12 PM »
It's a 1971 K1 750
1970 CB750K1
1976 CB750K6
Offline david 750f
  • 1976 CB750F
1976 CB 750F
« Reply #8 on: June 30, 2022, 07:49:46 AM »
Yamiya has stock ones and long ones if you choose to put on a set of engine protection bars
Offline david 750f
  • 1976 CB750F
« Reply #9 on: June 30, 2022, 10:31:06 AM »
David Silver Spares has the reproduction and some of the originals if you want to order from the US.
https://www.davidsilverspares.com/parts/by-part-number/
« Last Edit: June 30, 2022, 10:33:19 AM by david 750f »
1976 CB 750F
« Reply #10 on: June 30, 2022, 12:41:03 PM »
Big thanks to everyone in here!
1970 CB750K1
1976 CB750K6
