Author Topic: Carb sync tool question?  (Read 688 times)
Offline Skyguyz
« on: July 04, 2022, 03:57:27 PM »
So I purchased a set of vacuum dial gauge type carb sync tool. Unfortunately, the brass screw-in fittings for the vacuum hoses do not
fit due to clearance issues / interference with the adjoining carb on the # 2 & 3 carb.
what vacuum sync tool fits the 76 Honda CB 750 K6 with no interference issues & works fine AND won’t break the bank? Thanks in advance as always. (I’ll get this bike dead nuts tuned soon. Runs fine but,,,,)
Sky
Re: Carb sync tool question?
« Reply #1 on: July 04, 2022, 04:22:42 PM »
Shorten them to fit? Mine also foul the choke mechanism, so I usually warm the bike up a bit before fitting them.
Offline Scootch
  • Someday I'll know what I needed to know years ago
« Reply #2 on: July 04, 2022, 04:38:42 PM »
Common Motor Collective might have something that can help you...  You'd have to ask them if the threads will work for you...
https://www.common-motor.com/honda-360-carb-ports
« Last Edit: July 04, 2022, 04:43:17 PM by Scootch »
Offline Scootch
« Reply #3 on: July 10, 2022, 05:55:08 AM »
I have also become aware of these...
https://www.motosport.com/motion-pro-brass-vacuum-adapter-with-cap
They might work for you. I believe you would want the 5mm ones...
Offline Airborne 82nd
« Reply #4 on: July 11, 2022, 06:55:02 PM »
They make flexible ones I have two sets will dig them out to see who makes them. Can not remember where I got ten 10-15 years ago.
