Author Topic: Electrical Diagram Does Not Compute  (Read 778 times)
Offline John G
  • A 1975 CB Rebuild
« on: July 12, 2022, 01:27:28 PM »
Did I ever tell you how much I HATE electrical. With my nice new main wire harness that came with the bike (which I recently purchased) installed it's time to hook up the rats nest of wires. Looking at all the pictures I took I figured; how hard can it be. Looks like I need a wiring diagram. Ok. Looking at the wiring diagram I thought I would start at the easy stuff so I look at the three wires for the right turn signal light. Yeah, I think I understand where they're going. Three wires; hmmm. The wires that are coming from the right turn signal light are the wrong color and there are only two wires. #$%@%&&^(*^ Is it me or do you need a degree in brain surgery to figure this stuff out. Does anyone have a better wiring diagram I can follow. Black wires with white tape. Three wire into a junction terminal and I still more of the same color wires. Do you think a HONDA Shop would be able to figure it out? Crazy.  Did I ever tell you how much I HATE electrical
John G.
Re: Electrical Diagram Does Not Compute
« Reply #1 on: July 12, 2022, 02:29:20 PM »
3 wires would indicate each side has a running light AND a turn signal for the front only.
Supposed to be as easy as connecting like colors  :-\
Online newday777
« Reply #2 on: July 12, 2022, 03:48:46 PM »
When you say 3 wires do you mean the 2 orange, orange/white, and the ground?? Otherwise you will have to be more specific.
Online newday777
« Reply #3 on: July 12, 2022, 03:49:44 PM »
And what bike is this on?
Offline John G
  • A 1975 CB Rebuild
« Reply #4 on: July 12, 2022, 04:57:55 PM »
Thanks Guys. More less looking for sympathy. I hate wiring. I have to figure out how to list my bikes and at least let you all know what I' working on. I'm very excited to have this bike. The motor still has to come apart and reassembled. It is in very good shape. Always stored inside. Only has 16K on the speedometer. Likely not 116K but they original owner before he passed away stared a restoration which I will do. It's a 1975 CB750K.
John G.
Online newday777
« Reply #5 on: July 12, 2022, 05:56:34 PM »
Cool!
I just happened to plug the rats nest back together today on my 75 K5 Planet Blue after changing the handlebars, so I understand......
I still remember swearing at the Japs for putting so many wires in such a small space changing the handlebars back in the 70s when I had to stay late after a 12 hrs day as Parts manager and having set up parties till the wee hours of the night and of course the new owners wanted higher bars on their bikes...amongst other touring accessories.
Offline John G
  • A 1975 CB Rebuild
« Reply #6 on: July 12, 2022, 06:17:29 PM »
We have the same bike. Nice. Mine still has the original exhaust and wheels. The paint job looks blue but apparently its called an off green or something like that.
John G.
Online newday777
« Reply #7 on: July 12, 2022, 07:15:43 PM »
The K5 only came in Planet Blue and Flake Apricot Red. There was a green(Freedom Green Metalic)in 74 though.
The K4 had smaller turn signals than the K5 too.
« Reply #8 on: July 12, 2022, 09:53:05 PM »
I used both Honda diagrams found in the CB750 shopmanual and colored simplified versions found in the diagram download section.
I built my CB750 K2 with stray parts. New aftermarket main harness (loom), aftermarket bar switches. All wiring new.
It worked direct. Except for LED pilot bulbs of bad quality that popped within minutes. Stock versions in saved the day.
I had to think extra about the blinker buzzer since I had one with 3 wires (probably G1000 version)
The bar switches verified with a buzzer before connecting them. I marked the wires with tape to be sure. Some wires have not same colors as stock.
I have also seen 3 wires to fron blinkers in the diagram. Not on my bike.
This on US bikes only with that type of blinkers and bulbs with 2 functions (like rear lamp with brake)
Just follow diagram and connect.
I did the same on my K6 that got new bar switches where functionality was checked before connection.
Never a problem.
Only issue I have had was the jumper wire between brown and black, almost invisible in the diagrams.
I think it was the instrument voltage not functioning without it.
Online newday777
« Reply #9 on: August 08, 2022, 07:03:17 PM »
John
Did you get the wiring figured out?(you left your thread hanging unfinished....)
« Reply #10 on: August 09, 2022, 04:59:24 PM »
I like wiring them, too bad you don't live closer.  I even converted a 400F to European switches and lights just for fun.
