Author Topic: What did you do to your non-SOHC4 motorcycle today?  (Read 44098 times)
Re: What did you do to your non-SOHC4 motorcycle today?
« Reply #250 on: August 13, 2023, 08:20:31 PM »
I'm surprised to see the condition of those o-rings Gregg;I installed a Dynojet Stage 1 kit in my 91' CBR1000F.
I left the OEM slide springs in place,even though the kit directions said to install their springs;in hindsight I should have changed them also. I gave the Dynojet slide springs to the new owner.
« Reply #251 on: August 13, 2023, 08:36:18 PM »
I bought my 1990 CBR1000F on October 4th, 1990 from Hartley Motors in Wasilla, AK.
Late last year I was recruited to try to repair a machine for a fellow named Rob, that makes leather holsters, known as Simply Rugged. He also used to live in Wasilla, and still has connections/relations there. Nice guy!
« Reply #253 on: August 14, 2023, 07:00:27 AM »
She is a beauty.
Yes, very sharp looking bike, Greg.  I'm not surprised to see the bad condition of the o-rings, that is ethanol fuel at work.  Nice job getting it back out there.
Online RAFster122s
« Reply #254 on: August 14, 2023, 08:11:18 AM »
That’s great Greg!  Maybe Claus Studios would be able to make replacement diaphragms?
« Reply #255 on: August 14, 2023, 03:16:03 PM »
There are just so many cool bikes out there, soooooo tempting.
Offline ofreen
« Reply #256 on: August 14, 2023, 10:34:51 PM »
How long ago was that?  33 years for o-rings doesn't seem too bad.  One thing about getting old is I notice I am outliving rubber and plastics.
It will be 30 years next month since we moved from Alaska.  Weird to think about.
She is a beauty.
Fit and finish on those bikes were very good.
Thanks Stev-o.  It may be remarkable they lasted as long as they did under the circumstances.
Thanks David, I'd never heard of that outfit so I looked them up.  Very interesting.  There are chinese-made diaphragms on feebay.  Hard to say what the quality may be like but they are cheap so I may buy one to have a look.  But my experience with chinese rubber (and cardboard) hasn't been favorable over the years.
So many bikes, and so little time (and money).
Greg
'75 CB750F
Offline Kelly E
  • Geriatric Hooligan
« Reply #257 on: August 19, 2023, 03:08:57 PM »
Today we worked on Glen's bike. The vacuum petcock had a tiny leak in the diaphragm and dumped into the crankcase. It blew oil all over the motor so we cleaned it up and replaced the petcock along with a fresh set of plugs. Got it running good again so Paul took it out for a short 4 mile test run. There's fresh oil all over the transmission/starter cover area again. It's for sure leaking from the head gasket at the front of the cam chain tunnel and maybe more spots.
So it's blown out the head gasket and while cleaning it up I found bad cracks in the stock exhaust system. The bike only has 16k miles on it and is worth fixing. We're waiting for a decision on the repairs and exhaust system replacement.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #258 on: August 19, 2023, 03:12:37 PM »
Kelly,do you think the head gasket being blown out might have been caused by the mix of gasoline/oil,running it around like that ?
Offline Kelly E
« Reply #259 on: August 19, 2023, 03:19:10 PM »
Yep, he didn't know anything was wrong until it oiled down his legs.
1983 Honda CB 1100F
Offline spotty
« Reply #260 on: August 19, 2023, 06:31:38 PM »
The bargewing has had its clutch hydraulic fixed now, big thanks to Terry for help. Not going to register it until next year when I can put it on classic reg, $90 per year instead of $800.
May get tempted and slap a current plate on it for a few sneaky rides over summer though
i blame Terry
Offline spotty
« Reply #261 on: August 19, 2023, 06:38:30 PM »
Poor old Royal Tour Star , still on the backburner but I thought I'd get its cover off for the first time since it had a good old go at wrecking my back last summer ( no brakes, rolling it backwards off the bike lift and it took off on its own, it didn't fall but my back took the strain )
I'm thinking of junking a lot of the bodywork, just have panniers.
It also needs new tyres and brakes and the rear air shock seems to have lowered itself since I last looked at it
When it does hit the road it'll share registration with the vmax
i blame Terry
« Reply #262 on: August 20, 2023, 05:50:51 AM »
If the clutch is in working order backing bikes off a ramp in first gear and using the clutch as a 'brake' can be helpful.
Offline CycleRanger
  • No comment about being an
« Reply #263 on: August 20, 2023, 08:48:58 AM »
Spent about three hours yesterday cleaning blue RTV off the top end of the CL350 I'm working on.
The most egregious use of RTV I've ever seen on an engine. Thankfully, so far, I haven't found much actually in the engine.
Offline Kelly E
« Reply #264 on: August 20, 2023, 04:31:09 PM »
Looks like it was used anywhere there was a gasket. :o
1983 Honda CB 1100F
« Reply #265 on: August 20, 2023, 05:01:24 PM »
I'm looking forwards to us going for a ride, you with your dodgy number plate on your Barge-Wing, and me on my other Rocket III with plate borrowed from my other Red Rocket III. (we better take a tow rope so you can tow me home.........) ;D
« Reply #266 on: August 20, 2023, 05:24:17 PM »
Rode it for the first time!
Offline spotty
« Reply #267 on: August 20, 2023, 06:18:50 PM »
I'd robbed the clutch s;lave cylinder off the bargewing to use on the Vmax
i blame Terry
Offline WhyNot2
  • I'm finally an
« Reply #268 on: August 21, 2023, 05:26:40 AM »
I know that feeling........
Offline CycleRanger
« Reply #269 on: August 21, 2023, 06:58:27 AM »
Hey, at least they used the high temp stuff!  ::)  :P
Offline WhyNot2
  • I'm finally an
« Reply #270 on: August 22, 2023, 05:30:14 AM »
lol......yes they did.....::) ;P
Offline budman
  • 1914X
    • LeCompte Electric Bass
« Reply #271 on: August 24, 2023, 01:28:52 PM »
I washed the Scout bright and early, pulled it into the shop and onto the bike lift.  I anticipated pulling the wheels off so I can take them in to get new tires installed tomorrow, but I hade to run some errands that took me a lot longer than I expected.  When I got back home it was too stinkin’ hot.
Instead, the wheels are coming off early tomorrow morning.  I’m also picking up a new fairing for the bike tomorrow…and also on the list for Saturday morning is an oil change, all fluid check, inspection and a thorough detail.
« Last Edit: August 24, 2023, 01:30:56 PM by budman »
Bud
1973 CB750K3 Chopper
2021 Indian Scout
« Reply #272 on: August 24, 2023, 02:12:12 PM »
I’m always envious of you folks that have a nice lift.
Nice Scout!
Offline spotty
« Reply #273 on: August 24, 2023, 03:53:17 PM »
Nice Scout!
makes a massive difference to any work you're doing. terry and i just pulled the motor on his Rocket 3 and i cannot imagine the hell it would have been doing it on the floor
i blame Terry
Offline Kelly E
« Reply #274 on: August 24, 2023, 03:56:34 PM »
I'm charging up a fresh Yuasa AGM battery for the 84' Sabre 700S. The last one was an Interstate AGM and had been in there for 2 years after the R/R died high and cooked the previous regular battery. The Interstate died when the starter solenoid shorted out. I replaced the solenoid and the battery would charge up but when I turn on the key the bike didn't power up, the battery instantly dropped to 9v.
1983 Honda CB 1100F
