Author Topic: What did you do to your non-SOHC4 motorcycle today?  (Read 41567 times)
Herr Supersport and 3 Guests are viewing this topic.
Online BenelliSEI
Re: What did you do to your non-SOHC4 motorcycle today?
« Reply #675 on: November 18, 2024, 06:37:51 AM »
Well done Terry. That bike looks great, and the low dollars make it even better!
« Reply #676 on: November 18, 2024, 01:20:28 PM »
Thanks John, it’s a lovely thing, I’m really looking forward to the next ride. ;D
Online CycleRanger
  • No comment about being an
« Reply #677 on: December 08, 2024, 11:38:01 PM »
Installed a Tytronic electronic advance ignition on my CL350.
It works as advertised, for now.
« Reply #678 on: December 09, 2024, 12:20:51 AM »
Excellent  :)
Online BenelliSEI
« Reply #679 on: December 12, 2024, 01:20:33 PM »
I do enjoy fiddling with points, gap, dwell and timing….. Having said that, every time I install one of these, I wonder why I bother! Slick.
« Reply #680 on: December 19, 2024, 12:49:55 AM »
I’m reviving the VTR1000F “Streetfighter” build I started 8(?) years ago when I bought a badly crashed VTR1000F with all the plastics destroyed to build a poor mans Ducati S4 Monster, before I eventually bought two S4’s. The carbs and tank got a clean and it fired right up. Just need to install the OEM exhausts and replace the front MC, and it should be good for a sneaky ride. ;D
« Reply #681 on: December 19, 2024, 12:58:16 AM »
Nice.  :)
What did you finally do with those two S4's Terry ?
« Reply #682 on: December 19, 2024, 06:36:42 AM »
Too bad the Tupperware (plastic stuff) is so expensive. Lots of good bikes go without after one small crash or fall over.
Online CycleRanger
« Reply #683 on: December 19, 2024, 09:25:08 AM »
Excellent  :)
Yeah, an FYI about these. The points cover will contact and apply pressure to the pickups if a stock gasket is used.
This is bad and alters the timing and probably will contribute to early failure. The solution is to use a thicker (~3mm+) gasket.
Offline Magpie
« Reply #684 on: December 19, 2024, 09:43:24 AM »
Still a work in progress. Seat is out for a new cover. The swing arm is going to come out to check the bearings and re-grease them then a coat of paint. Exhaust system refurbish to follow.  New throttle cables on Santa's sleigh. Cliff.
« Reply #685 on: December 20, 2024, 02:08:17 PM »
G’day Steve, I had a ‘98 model with all the factory plastics and loved the big “L Twin” grunt, handling and brakes, but the ergonomics didn’t suit me at all, I could only ride it for an hour or so and my back, shoulders and wrists would kill me. I traded it and a couple of grand for a car when I was in Canberra.
A few months later I saw a very badly crashed ‘06 model going cheap (like me) so bought it. It was a stat write off so I couldn’t re-register it, but luckily for me I found a titled frame at a wreckers in Sydney so swapped across all the mechanicals which were good. The bike had slid down the road and hit a pole, so the tank was crushed so badly that it smashed the rear cylinders cam cover underneath. I hope the rider survived.
I purposely didn’t replace the plastics because I bought a special top triple clamp from Germany that allowed me to install higher handlebars, bought a nice tank, Corbin seat and a tiny fairing/headlight unit with indicators built in, replaced the damaged master cylinders with Ebay cheapies, but I actually think it looks pretty good. The PO had spent a lot of money on aftermarket adjustable rearsets, alloy velocity stacks, and manual cam chain adjusters, which are essential for the longevity of these bikes, as the only fault with VTR1000F’s are the failure prone OEM automatic adjusters. It also had Yoshimura slip on mufflers, although one was destroyed in the crash so I had to find another one and adapt it to fit.
Last night I installed some OEM mufflers because the Yoshi’s won’t pass the noise level test when I take it in for a Roadworthy Inspection. While I was trawling thru Facebook Marketplace I saw a Honda Varadero going cheap and contacted the owner and I’m going to swap my Yamaha DT250 for it on Monday. It will need some TLC and a paint job, but should be a great adventure bike, so I’ll paint it black and swap the plate between it and my current one as they’re both 2006 models so the cops won’t know the difference. (I hope)
Ironically I gave up on this project 8 years ago after badly burning my leg on the exhaust, and last night after installing the OEM pipes, I managed to burn it again. From now on, any time I’m working on it I’ll wear long pants.
Bill, I still have both Ducati S4’s. I sold the red one to my son, so Spotty and I are working on the black one, so that my son and I can go for a ride together. Anyway it’ll be nice to finally get the Honda on the road. ;D
« Reply #686 on: December 20, 2024, 11:00:45 PM »
Terry, they make a silver infused cream specifically for burns…it will speed healing of your burn and lessen chances of infection. Silver is naturally antimicrobial
