Author Topic: What did you do to your non-SOHC4 motorcycle today?  (Read 43618 times)
Re: What did you do to your non-SOHC4 motorcycle today?
« Reply #725 on: January 04, 2025, 01:16:14 AM »
Evaporust is weird as I hear some getting great results quickly while others report week or more to get good results. The chelation process used by Evaporust, Metal rescue Oxalic Acid and others likes heat and it does take time. I wonder if fuel varnish is causing it to be slowed?
Congrats on the ride and enjoyment
« Reply #726 on: January 04, 2025, 04:58:44 AM »
You are on it Dave about the fuel varnish effecting the results and time.
Offline Kelly E
  • Geriatric Hooligan
« Reply #727 on: January 04, 2025, 11:54:16 AM »
We rinse the tank with acetone to clean out the fuel residue and dry before the EvapoRust.
EvapoRust lasts a lot longer when you clean oil/grease off first.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline CycleRanger
  • No comment about being an
« Reply #728 on: January 04, 2025, 01:26:13 PM »
+1 on cleaning any varnish & residue out of the tank. It won't touch anything but rust.
I've had good results with evaporust but it can be slow on heavier rust. Keeping it warm and agitation helps.
I ordered some Gen-U-Wine Keihin jets for my CL350K3 today.
Probably should have done it months ago.
Having some issues with the carbs and the existing brass came from who knows where.
    • http://forums.sohc4.net/index.php?PHPSESSID=pgct1tprm3kb61t86t4qvi80g4&/topic,60973.0.html
« Reply #729 on: January 05, 2025, 05:25:36 AM »
got a china ybr yamaha for driving to work...for road reg i needet a orginal exhost system(e)uro stamped..faund one in italy vith e stamp..fixed the leaky forks legs..and some corodet viring..and it vent through the test ..runs fine ..but topspeed is max 90 kmt 10 hp for a 125cc ..its not a mad max machine
« Reply #730 on: January 05, 2025, 02:53:46 PM »
Well after several days of Evaporust in the tank it cleaned it much better than last time. I drained the Evaporust out and flushed the tank with boiling water and a little detergent then after draining it again used my heat gun to dry it out.
Being that it was 100 degrees yesterday the tank got very hot very quickly so no obvious flash rusting. Sprayed Inox lubricant (like WD40, only better) into the inside of the tank, and this morning it still looks good. When the rain stops I’ll flush it again with some oily petrol before fitting it to the bike and filling it with fresh fuel, and it should be good. ;D
« Reply #731 on: January 05, 2025, 02:55:28 PM »
You can keep it stored,then when you have a guest visit you in Summer,they can use this 125 motorcycle.
Online Magpie
« Reply #732 on: January 05, 2025, 04:55:46 PM »
Got the carbs installed and the air box attached to it on the 1100F after many frustrating hours. New throttle cables too. Next job is painting the exhaust headers.
« Reply #733 on: January 06, 2025, 07:40:33 PM »
Looking very good!
Offline Kelly E
« Reply #734 on: January 09, 2025, 03:01:12 PM »
We've learned on the 82' CB 900F that when assembling the airbox everything has to be at just the right angle including the carbs for it all to go together nicely. Seems like it's just as finicky as the CB 550 and soon we'll have to get started on the 83' CB 1100F. ::)
1983 Honda CB 1100F
« Reply #735 on: January 09, 2025, 07:56:46 PM »
Cliff, I cannot see how you would be rejected for the vintage plates given your attention to detail and refreshing the finish on everything that needs attention. I think they would be hard pressed to find fault with your work and think it anything less than more than acceptable.
Best of luck with the exhaust touch ups repaint...
