« Reply #26 on: April 10, 2023, 03:53:26 PM »
The bars are most likely the same as from 4into1.
BTW there's a SoCal 750 group in the Orange county area, they are meeting at Cars and Coffee on Saturday morning if you want to go for a ride. Good group of guys. They just rode up north this past weekend.
Where do I adjust the carbs to make it run richer at WOT at?
I took it to a shop last October and the guy did something to the carbs...said he turned the screws out a turn or so. Now it runs really good....doesn't miss at part throttle or while pulling from 0-7K rpms, but when I go WOT past 7-8K rpms it acts starve again, begins to stutter a little...keeps pulling though. I tried it with the choke closed a little to see if it got worse or better and it definitely got worse, so it is not getting too much fuel, must not be getting enough gas up top now. Unless it's because the gas is 6 months old??? It's been in the tank since last October.
The rest of the rpm band from 0-7K rpms runs great in all gears after I'm at cruise 3-4K rpms.
I still have to order the shorter cable from 4into1.
What main jets do you have in it?
Did you do plug chops yet?
Logged
Stu
My current rides
Prior bikes....
