Author Topic: pictures of K1 dual disc caliper mounts  (Read 2088 times)
Offline Shtonecb500
    • Youtube profile
« on: July 16, 2022, 12:20:45 PM »
Seeking pictures or links to threads with overview of the K1 C bracket caliper mounting system for dual discs.
I found a couple different brackets and im confused.
thanks.
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Offline newday777
Re: pictures of K1 dual disc caliper mounts
« Reply #1 on: July 16, 2022, 01:05:01 PM »
On a 750 K1?
Stu
My current rides
Prior bikes....
Offline Shtonecb500
    • Youtube profile
« Reply #2 on: July 16, 2022, 01:12:46 PM »
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #3 on: July 16, 2022, 01:56:14 PM »
Which part is causing you confusion?
« Reply #4 on: July 16, 2022, 02:46:04 PM »
The correct mirror image bracket for the early ones is very rare and expensive as it was magnesium alloy in the race kit.
You can convert a lh one to rh by machining off a boss and using spacers.
I believe yamiya do the bracket but it aint cheap
Offline gschuld
« Reply #5 on: July 16, 2022, 03:12:13 PM »
+1.
Checkers Flag Customs(Yoshimura) sold the custom magnesium right side C brackets for the early fork lowers(69-71) a long time ago.
Modifying the factory left side bracket into a right side bracket is the normal method.  I can take pics of a geniune CFC right magnesium side bracket if that helps you, but no, mine is not for sale.
George
Offline grcamna2
« Reply #6 on: July 16, 2022, 03:25:31 PM »
subscribed
« Reply #7 on: July 16, 2022, 04:30:09 PM »
 Let me try this pic. Not the one I was looking for but close. I also have a set of left and right that were cut down for a fiberglass fender drag bike.
« Last Edit: July 16, 2022, 04:36:45 PM by Don R »
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #8 on: July 16, 2022, 04:39:54 PM »
Sure looks harder than the T bracket to mount
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline commander60
« Reply #9 on: July 16, 2022, 04:49:16 PM »
Speaking about brackets , anybody ever put the caliper on the back site ? I did years ago on my CB500. can't Rember how I did it !
Offline gschuld
« Reply #10 on: July 16, 2022, 06:06:46 PM »
Just reposition the forks backwards.
George
« Reply #11 on: July 16, 2022, 06:07:01 PM »
Yup i did it in 76 when i twin disced a 500, had to have one caliper in front and one behind as there were only caliper mounts on the lh slider, we had the 500 till 77 then the 550F had mountings on both sides
« Reply #12 on: July 16, 2022, 06:57:42 PM »
+1.
George
Here's a couple three pics of a CFC bracket. It was designed to be used with the stock fender brace, which fit between the bracket and fork leg. If the fender brace wasn't used, washers were needed or the caliper would sit crooked. Also, the brake line seat needs to be removed and reinstalled in the old bleeder hole to convert the caliper to right side use.
edit: found another pic of the CFC bracket and one of the flare seat.
« Last Edit: July 16, 2022, 07:03:02 PM by scottly »
Offline newday777
« Reply #13 on: July 16, 2022, 07:03:08 PM »
On my K6
Stu
My current rides
Prior bikes....
Offline Shtonecb500
    • Youtube profile
« Reply #14 on: July 16, 2022, 08:06:36 PM »
Guys, THANK YOU SO MUCH for these pictures and the info. I was sitting there earlier just holding it up to the fork lower trying to figure what i would cut...I see the yamiya RH clamp runs about 200 usd plus shipping. It looks like I have what I need to accomplish this task though.
here is pic of the one you can buy from yamiya and what i have
« Last Edit: July 17, 2022, 05:59:06 AM by Shtonecb500 »
Offline Shtonecb500
    • Youtube profile
« Reply #15 on: July 16, 2022, 08:06:57 PM »
lol thats what i was thinking.
Offline Shtonecb500
    • Youtube profile
« Reply #16 on: July 18, 2022, 07:24:18 PM »
Lol
so if i shave the lower rear boss down then i should need 1 or 2 less washers (mm's)? It lines up over the rotor fairly well the way i have it, the bolts dont come close to any spokes but it would better if have something less chunky.
« Last Edit: July 18, 2022, 07:28:48 PM by Shtonecb500 »
  • Gusto mo titi ko?
    • project
« Reply #17 on: July 18, 2022, 07:46:00 PM »
Yes, less clunky is the way to go!
« Reply #18 on: July 18, 2022, 11:07:56 PM »
Yup, the shorter the bolts are and with fewer washers the stronger it will be.
« Reply #19 on: July 19, 2022, 10:02:11 AM »
Rookster gave some details on modifying and spacing the early caliper bracket in this thread:
http://forums.sohc4.net/index.php/topic,91781.msg1025007.html#msg1025007
Offline Rookster
« Reply #20 on: July 19, 2022, 04:38:22 PM »
Thanks for posting that link.  I had forgotten I wrote that up.  I have had to modify my setup since going back to the stock fender.  The K1 fender has to bolt up tight to the RH fork leg.  Here is how I did it with the stock fender: 1/4" spacer and thick shim washer plus the fender bracket got the caliper in the right spot.
Scott
Offline Shtonecb500
    • Youtube profile
« Reply #21 on: July 19, 2022, 05:55:19 PM »
thanks for the links and pictures everyone, made this much easier.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #22 on: July 20, 2022, 01:32:18 PM »
Jeff Stephens at Godffery's Garage makes a comprehensive kit. He also offers rotor thinning and drilling services. I have three of his thinned and drilled rotors on my 750F and my 550F had one on the front. He does really quality work and I have been fortunate to visit his workshop in person. You can check it out at his website: godfferysgarage.com
Offline Shtonecb500
    • Youtube profile
« Reply #23 on: July 20, 2022, 08:08:46 PM »
I have his set up on a 550  :)
Offline Shtonecb500
    • Youtube profile
« Reply #24 on: August 25, 2022, 12:31:51 PM »
+1.
George
tips on removing the line seat?
