Author Topic: is this going to be an issue? cb500 motor  (Read 410 times)
Offline Shtonecb500
    • Youtube profile
« on: July 16, 2022, 12:34:50 PM »
this was siliconed on, you think this will be a problem?
cb500-4
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Re: is this going to be an issue? cb500 motor
« Reply #1 on: July 16, 2022, 02:48:50 PM »
There should be an O ring on the stud before the washer to stop any oil
Offline grcamna2
« Reply #2 on: July 16, 2022, 05:48:15 PM »
I could be wrong but it looks like a bottom section of that casting where the bolt goes in has been broken-off,then glued on?
« Reply #3 on: July 16, 2022, 06:09:21 PM »
Dont think its broken just corroded a chewed up
« Reply #4 on: July 16, 2022, 07:05:13 PM »
The area could be TIG welded and refaced but I think their silicone solution will work if it keeps it from leaking while allowing it to seal. Crude but effective. Would need the head off ideally to do that repair out of the motor…
Offline Dunk
« Reply #5 on: July 20, 2022, 05:13:14 AM »
If that washer does the sealing on a 500, it will leak there. I would clean it well then use epoxy like JBweld then file/sand it smooth.
« Reply #6 on: July 20, 2022, 05:46:06 AM »
The washer dont seal, the O ring does and will probably deform into the erroded areas ans seal fine
Offline Shtonecb500
    • Youtube profile
« Reply #7 on: July 20, 2022, 06:35:13 AM »
we decided to just rebuild the original head and use parts out of this damaged one.
