Author Topic: K7 front sprocket torque spec?  (Read 696 times)
Offline timmerk
« on: July 20, 2022, 09:39:26 AM »
Does anyone know the torque spec for the single bolt on the front sprocket on a K7? It doesn't have the two smaller bolts on the sprocket like earlier models have. I keep seeing references to http://www.salocal.com/sohc/tech/torquetable.htm, but that site no longer exists, and the Wayback Machine didn't pick up a copy. Thanks!
Re: K7 front sprocket torque spec?
« Reply #1 on: July 20, 2022, 07:18:06 PM »
It's tough to torque as any sizeable wrench is gonna turn the engine over.  Several ugga dugga's from a battery impact has worked well for me in the past.  Probably gonna want some blue loctite on there too.
Offline enwri
  • So that noise is normal?
« Reply #2 on: July 25, 2022, 08:51:08 AM »
Found this
77 CB 750 k.. 29 years and counting.
91 TDM 850 (No.34) so comfy and soft
8? XJ 550 meh...
76 XL 350 Super Sport stump puller..
80 XR 200 idiot proof
75 MX 250 b dangerous
« Reply #3 on: July 25, 2022, 02:25:57 PM »
Found this
That's weird: I didn't know the K7 has a 'flywheel'.
Link to website: SOHC4shop.com  (Note: no longer at www.SOHC4shop.com, moved off WWW. in 2024).
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #4 on: July 25, 2022, 02:42:19 PM »
Where would a flywheel be?
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline scunny
  • don't call me expert
« Reply #5 on: July 25, 2022, 09:43:14 PM »
alternator rotor.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
« Reply #6 on: July 25, 2022, 10:54:39 PM »
Found this
drive sprocket 13-15.9 ft lbs.
Offline jpdevol
« Reply #7 on: July 26, 2022, 12:05:21 AM »
Yep, parts fiche show M8 x 20 bolt with captive washer 15 ft.lbs - loctite blue please
https://www.cmsnl.com/products/bolt-wash-8x20_934120802000/
Offline rotortiller
« Reply #8 on: July 26, 2022, 03:42:17 AM »
Lots of guys would remove the flywheel (or cut down) on racing bikes to enhance engine acceleration and run a total loss electrical system. Made a noticeable improvement removing all that flywheel inertia. The only concern was that the oil hole needed blocking on the crank.
Offline timmerk
« Reply #9 on: July 26, 2022, 10:02:23 AM »
Thanks all! Doesn't 13-15.9 ft lbs. seem way too low? I'm sure I overdid it by using a battery impact, but since I added blue loctite, already put the transmission cover back on, and filled with oil, I figured I should leave it and not add more stress to the bolt by loosening it - or is that dumb thinking? Maybe I'm just lying to myself! :D
« Reply #10 on: July 26, 2022, 10:27:03 AM »
Don't worry about it.. ;)
Offline enwri
« Reply #11 on: July 27, 2022, 11:16:45 AM »
It doesn't get any real load on the bolt, it just clamps the washer on so the sprocket cant slide off the end. The sprocket isn't held tight by the bolt.
There's a bit on the inside of the cover that will contact the bolt if it does come loose, which also winds it back in when it touches. Better to come loose than pop the head off the bolt, sprocket can't get off the shaft until the bolt is gone. Bolt can't screw far enough out with the cover on.
Found this
It's way down in the PTO and Accessory section, It's recommended to be used with both the Hay Baler or Rock Crusher Attachments.
Maybe it's just in the Australian  K7 supplement.
8? XJ 550 meh...
