I don't hear much alarming soundwise. Maybe your tappets are a bit on the wide side. IN should be 0,05mm and EX 0,08, but 0,10mm for the latter is also OK. Do you know how to adjust them?
You may check oil arrives sufficiently up there. Remove a tappet cover and have the engine idle. When it spits oil out at you, it's OK.
