Author Topic: ‘77 CB750 F2 Fork Questions  (Read 942 times)
Offline zalion0
« on: July 29, 2022, 01:50:46 AM »
Hi All, the current front forks on my 1977 CB750 F2 are pitted so I ordered some replacements (from David Silver who are usually spot on) however they appear to be different size.
What I’m trying to work out is if the replacements are indeed suitable. The diameter is fine, the replacement tube is approx. 20mm longer and the oil hole at the bottom is approx. 81mm from the bottom on the replacement vs 65mm on the original. The fork top cap however fits on both.
Given I have no history of the bike, I can’t determine if the original forks are indeed Original (I’m fairly confident they are). So, to return the replacement or re chrome originals.
Online newday777
Re: ‘77 CB750 F2 Fork Questions
« Reply #1 on: July 29, 2022, 04:20:15 AM »
Did you contact David Silver about those differences?
Stu
My current rides
Prior bikes....
Offline zalion0
« Reply #2 on: July 29, 2022, 04:22:32 AM »
I will be, just trying to pre empt the response of these ‘being the right forks for the right bike’ and tap into the excellent knowledge of the people here :)
« Reply #3 on: July 29, 2022, 05:54:03 AM »
Good idea to verify which fork tubes your model should have and what you got.
Your old pitted tubes might have been replaced before?
According to this site, lenght should be 585mm
https://www.wemoto.com/bikes/honda/cb750f2sohc/78/picture/fork_tube_-_stanchion_-_single
588mm here, searched on partnumber found at Cmsnl
https://honda4parts.nl/product_info.php?products_id=2240&language=en
« Last Edit: July 29, 2022, 06:20:20 AM by PeWe »
Offline Bankerdanny
  • Endeavor to persevere
« Reply #4 on: July 29, 2022, 08:05:59 AM »
I know that the F model forks are slightly longer than the K model forks due to a change Honda made in the neck angle. I don't know if there is a difference in tube length between single disk F0/F1 and the dual disk F2/3
Offline zalion0
« Reply #5 on: July 29, 2022, 08:22:35 AM »
Yep, after doing some research it should a case that the original forks are around 580mm in length which matches the current set I have. So we are confirming a few things.
