Author Topic: I think I fried my reg/rec?  (Read 348 times)
Offline Pielz
« on: August 03, 2022, 06:55:19 PM »
1977 CB750k here, I was out riding the other day and I'm not totally sure how it happened but my buddy pointed out a wire hanging down by my back tire. I traced it and it was the hot wire from my rear right turn signal. I was out on the road and had no way to tape it up so I wrapped it around a piece of the frame with the end of the wire sticking out so it wouldn't touch anything. By the time I got back to town my turn signals weren't working and the horn wouldn't honk. My ignition started sagging and the bike would bog, I barely made it home.
I looked and the hot wire had slipped from where I had it secured, grounded to the frame, and had drained the battery. I threw the bike on the charger, fixed the wire, and when I took it back out today thinking all was well it wanted to die on me again after about 35 mins of riding! I checked my stator just as a sanity check and got the .2ohm resistance reading between the yellow wires, all good there. I havent had the original reg/rec units in ages. I have a replacement combo unit, not sure where from, and I'm starting to suspect that little wiring issue fried it. Am I correct to assume that? Does this sound about right? I tried checking with a multimeter on diode setting between the red wire and the three yellows on the reg/rec wiring clip but I was getting values in the 500s. I'm not a great electrician.. I can read and understand a wiring diagram and rewire correctly, but that's about it lol. Any input would be wonderful!
Sent from my SM-G990U using Tapatalk
Online Don R
Re: I think I fried my reg/rec?
« Reply #1 on: August 03, 2022, 07:06:40 PM »
 Unless you have running lights in back it's doubtful the turn signal wire caused a charging system failure. If it went to ground, it should have blown a fuse. There are guys more versed in checking charging systems than I so I'll leave it here.
Offline Pielz
« Reply #2 on: August 03, 2022, 07:52:31 PM »
That was sorta my thought too! I guess it could be a totally crazy coincidence.. I have an AGM battery as well, in case that makes a difference. All the fuses are intact as well. That was my first thought when the turn signals stopped working.
Oh! All the bulbs on the bike are LED as well. Not sure if that makes a difference or not. I went ahead and ordered a cheapo reg/rec anyway just to see and I'll probably order a nicer one down the road. I was just curious and wanted some input.
Thanks for commenting!
