Author Topic: I just don't feel like riding  (Read 4839 times)
Offline grcamna2
Re: I just don't feel like riding
« Reply #50 on: September 09, 2022, 10:15:00 AM »
When I was without motorcycle, rides in the jeep without top and doors reminded me riding a bike - the cold air in valleys, the smell of hay in summer - you dont get it in a car.
Yes, plus the fun of getting through or over something challenging.  Or getting stuck for hours in the middle of nowhere with only your ingenuity and whatever you have at hand to get you out.
Here's a pic of my uncle's '42 Willys MB stuck in the Escalante River circa 1950.  I have that jeep here.
Did your uncle ever tell you how he got the Jeep out ?
75' CB400F/'bunch o' parts'
Offline ofreen
« Reply #51 on: September 09, 2022, 11:59:22 AM »
He did.  That jeep has a lot of history.  Before he died, I kept bugging him to write it all down, which he did.  It is quite an epic, as he had a lot of adventures in that thing back when the world was a different place.  It took him and his buddy Blackie 2 days to get it out and across the river, which was flooding at the time with spring rains.
Here are a couple of more photos from back in the day.  I have two of the jeeps in the pics, one of which is my grandfathers '42 Ford GPW.  Some stories go with that one, too.  These were taken a couple of years later, after my uncle replaced his homemade plywood cab with a steel Koenig.
Greg
'75 CB750F
Offline grcamna2
« Reply #52 on: September 09, 2022, 12:06:06 PM »
ofreen,in reply #49 with your Uncle's jeep in the river and that log in front of it:was that log buried/waterlogged and slippery and he hit that which stalled his forward progress across the river ?
Offline ofreen
« Reply #53 on: September 09, 2022, 10:20:45 PM »
It is quite a story, so here is an abridged version.  There was a uranium boom in Utah back in those days, so they were out prospecting.  They weren't on any road and had forded the river a few days prior, marking the spot with rocks on both sides, then headed up into the hills.  The river rose in the days after.  The river was a lot higher and wider when they got back to it, but he found the spot and they debated whether or not  to give it a try.  They were about out of food, so their stomachs made the decision and they went for it.  The water was too deep and flooded out the ignition about halfway across.  They spent the next couple of days jacking the jeep up higher, propping rocks under it, and building a road with rocks across the bottom. There was water in the gas tank and crankcase, but he had extra oil and gas in jerry cans.  Once he got it dried out the best he could, it started and ran.  He drove it all the way back to Salt Lake.  The jeep made it, but was running bad.  He said the gear shift lever was so hot he couldn't keep his hand on it. It had the original Go Devil 4 banger.  Those flathead engines have a side plate that covers the valves and tappets.  He said that recess was completely packed with sand.  He found after teardown, the pistons had grooves in them that looked like tunnels in an ant farm.  It was amazing it got them home, but those old jeeps were legendary for the abuse they could take.
At any rate, the engine was shot.  He then fitted a flathead Ford V8 in it, one of the first to put a V8 in a jeep. That took no small amount of engineering.   Later, he put a supercharger on it, cutting a hole in the hood to clear it.  Then he cut up a 55 gallon drum to cover the hole, then later had to cut a hole in that when he installed what amounted to Tri-Power.  The flathead is long gone, these days a 302 from a Granada sits in there and the Tri-Power hole patched with riveted sheet metal. There is lots more to the story of that jeep (or 'Peej" as he called it), a lot of family history tied to it.   I'll attach a pic of it in its present state.
Greg
'75 CB750F
« Reply #54 on: September 09, 2022, 10:50:33 PM »
Legend has it that the first guy to swap a V-8 flattie into a Jeep was Stuart Hilborn, of Hilborn injection fame, during WWII. ;D
Offline grcamna2
« Reply #55 on: September 09, 2022, 11:03:36 PM »
I like it ofreen  8)
Offline ofreen
« Reply #56 on: September 10, 2022, 06:37:45 AM »
No doubt there were others back in the golden days of hotrodding, even some Cadillac V8 swaps?  One of the bigger challenges was fitting them into the engine bay.  You can see in the photo where my uncle extended the nose a bit to get some room for the radiator.
Greg
'75 CB750F
