I set the airbox side gap to 1/8". I took a picture of the engine side gap because that's what the 95chris took pictures of in the post you referred to before. I can take a picture of that but I don't see the purpose in comparing the airbox side gap to the engine side gap.
I don't remember the exact method I used 7 years ago but the photos in this reply makes me think I may have done it through the airbox side as well. I happen to have a spare set of
022A carbs so I thought I take a few photos of what's being asked. Here's a 1/8th drill bit that's just held tight enough to hold it in place (I moved it a bit to the side to take a straight on photo). Also included the engine side as well the the adjuster threads. Done on the #3 carb, idle knob is not engaged.
Because the air box side has the cut outs on the slide, and if he was setting the slide height on that side to the tiny gap, which is what he said he was doing, that would be wrong and could possibly have been the cause of his problems.
The gap on the air box side, when set correctly, is much larger than that.
Whichever side I did use (probably the airbox side like the image above) set the gap fairly close to what I posted in my previous post.
It's possible I may have just use the drill bit as a baseline and closed them further as evenly as possible during that time to limit the amount of light passing through. Maybe a carb sync can confirm those small differences but still waiting on my sync tool
. Slides were not adjusted during this time of this thread or when I pulled the carbs to change the main jet o-rings. Can't explain the difference in the amount of threads shown however...
Chris
quick edit: My apologies for the insane size of these images, just realized how absurdly massive they are if you click on them here! Open them in a new tab to size it to your monitor. I'll see about resizing them a bit better for viewing.
