I would put money on if you removed the engine the frame will spring so much the engine wont go back in. I have seen damage repaired but that is on the bad side, obviously hit something hard
I used to have the same problem when we did CX500 exchange engines. Drop the engine out and you would get a big twang, as it was only the engine holding the main frame straight
