Author Topic: Removing Side Cover Pin  (Read 469 times)
Offline Bristledisk
« on: August 23, 2022, 07:12:14 PM »
Has anyone got a good method for removing the side cover pin from the side cover? See images. The spring on the pin is held in place by another pin (circled in red) pushed into the hole at the top on the main pin. This small pin is pushing against the spring and doesn't want to move. The plastic side panel is brittle so I can't use too much force. Tapping the small pin failed as did trying to pull the small pin out with pliers despite liberal amounts of penetrating oil.
1977 CB400F, 1976 CB750F1, 1974 CB550K, 1975 CB550K, 1976 CB550K2, 1973 CB350F
Offline scunny
  • don't call me expert
Re: Removing Side Cover Pin
« Reply #1 on: August 23, 2022, 10:23:22 PM »
I wold cut the main pin halfway down. It should then come out. then make another post.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline pjlogue
« Reply #2 on: August 24, 2022, 12:31:03 AM »
I used a vise and correct sized drift to tap the roll pin out of my '76 GL1000 side covers.  If your roll pin is rusted you may want to try cutting either the roll pin or the main pin as scunny suggested.
Yes the side covers are delicate!
-P.
Offline Flyin900
« Reply #3 on: August 24, 2022, 02:22:11 AM »
Looks like a CB350F cover and I did two just recently. I used a set of small thin needle nose vice grips to push back the spring/washer on the stem and take the pressure off the split pin. I then used a second set of linesman pliers with flat jaws to push the split pin flush with mounting post. A small drift or pliers to grab the pin to then to push/pull out the remaining split pin from the post.
You can sometimes reuse the old pins, if not Princess Auto sells a box of various sized split pins that can be used to replace the original ones.
« Last Edit: August 24, 2022, 02:29:01 AM by Flyin900 »
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline Bristledisk
« Reply #4 on: August 25, 2022, 01:08:08 PM »
Thanks for the replies. They are indeed CB350F side covers.
I eventually removed the large pin/post  from the side cover by carefully dremeling off the sides of the small split pin and the spring came free. I then tapped out the remaining bit of small pin still in the post. No damage to the plastic side covers but its was a bit of a pain. The large pin for the side cover (83703-333-000) is no longer easily available so you don't want to damage either those of the side cover.
