SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
1971 cb750 starter motor won't ground
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 1971 cb750 starter motor won't ground (Read 652 times)
carvedtangent3
Full Member
on:
August 23, 2022, 07:42:23 PM »
Hi! I'm wrapping up the wiring on a custom cb750 build and my starter motor is not turning over when I press the start button. The m unit start light lights up and the solenoid triggers and voltage is going to the starter, but it will not turn over unless I touch a cable from the starter motor housing to the battery negative terminal. I'm using a brand new ricks starting motor too if that makes a difference. Thank you for any help!
Logged
scottly
Global Moderator
Really Old Timer ...
Humboldt, AZ
Re: 1971 cb750 starter motor won't ground
Reply #1 on:
August 23, 2022, 07:48:52 PM »
The starter is grounded through the engine case and the frame. Do you have a large cable connecting the battery negative terminal to a good frame ground?
Logged
carvedtangent3
Full Member
Reply #2 on:
August 23, 2022, 08:04:23 PM »
Thank you, I think that may be my issue. I've been building this bike from the ground up and have been building a custom wiring harness with not much experience. I appreciate the help!
Logged
Don R
My Sandcast is a
Saver of unloved motorcycles.
Reply #3 on:
August 24, 2022, 08:55:47 AM »
Some guys ground to the fame with the cable under the engine bolt on the outside of the frame, others prefer to place the ground cable against the engine case between the engine and frame. Actually, either will work.
Logged
beemerbum
Expert
Reply #4 on:
August 24, 2022, 08:59:05 AM »
Seems to me that prior to the 1972 K2 750, the big ground cable was between the engine and frame. From '72 on, the cable was outside the frame. Of course, either location is a good ground connection.
Logged
bryanj
CB500 Number 1000036
Reply #5 on:
August 24, 2022, 09:49:54 AM »
Remember NO PAINT on the bracket where the cable goes and engine touches, also NO PAINT where the small green round terminal bolts on
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
