Author Topic: 8mm crush washers for fork rebuild  (Read 1579 times)
Offline Scott S
« on: August 26, 2022, 10:45:38 AM »
 I need two of the 8mm washers that go on the bottom bolt of the forks (not the drain plug on the side....the Allen bolt underneath).
 I refuse to pay $15 for two genuine Honda washers. The copper washers from Harbor Freight don't crush and seal.
 Surely someone has found a source locally. Do any auto parts stores, home improvement stores, etc., carry the correct size crush washer? Where should I begin my search?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Kelly E
  • Geriatric Hooligan
Re: 8mm crush washers for fork rebuild
« Reply #1 on: August 26, 2022, 10:51:20 AM »
I buy them at the Carquest in town.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline Flyin900
« Reply #2 on: August 26, 2022, 01:47:53 PM »
If you still have the originals just flat file them relatively smooth again, then heat with a propane torch to glowing red hot to anneal them and quench them in a water bath and your good to go.
« Last Edit: August 26, 2022, 03:43:19 PM by Flyin900 »
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
« Reply #3 on: August 26, 2022, 03:59:22 PM »
or just re-use them doing absolutely nothing...has worked for me literally dozens of times
Offline Kelly E
« Reply #4 on: August 26, 2022, 04:44:30 PM »
I've also annealed lots of copper sealing washers. No leaks yet, if they are too deformed replace them.
1983 Honda CB 1100F
Offline WideAWAKE
« Reply #5 on: August 26, 2022, 05:14:49 PM »
Rebuilt many forks, always reused without doing anything, beyond knocking off a high spot every now and then.
Never had one leak.
If they were leaking, you can get copper washers at ace, or autozone (at least I can here).
Offline Scott S
« Reply #6 on: August 26, 2022, 06:17:50 PM »
 This has been the way I've always done it.
 BUT...for whatever reason, this bike, that has been off the road for at least 20 years, has decided to leak from the bottom of the forks while sitting still, waiting it's turn in my garage.
 I've always reused them before.
« Last Edit: August 27, 2022, 04:18:24 AM by Scott S »
'71 CB500 K0
'81 Yamaha XS650
« Reply #7 on: August 26, 2022, 08:35:10 PM »
Got any local foreign car (British usually) parts suppliers locally, with products usually has a small set of drawers of these kinds of things and more.
Was lucky to have a couple of these kinds of shops when I lived in Columbus Ohio.
Ace Hardware would be where I would start looking here in Southern AZ.
« Reply #8 on: August 26, 2022, 10:57:55 PM »
$15? Where is that? At CMSNL € 2,- a piece.
« Reply #9 on: August 27, 2022, 12:54:54 AM »
David Silver has them at $1.50 and $1.03
https://www.davidsilverspares.com/CB500K0-FOUR-1971-USA/
Offline Scott S
« Reply #10 on: August 27, 2022, 04:19:15 AM »
 Yeah, but nobody is shipping them for free. It would cost me $16 total to get two washers shipped.
'71 CB500 K0
'81 Yamaha XS650
« Reply #11 on: August 27, 2022, 05:31:04 AM »
Forks.
They shouldn't be more than $2 at your local shops....
Offline BostonBob
« Reply #12 on: August 27, 2022, 05:58:17 AM »
McMaster-Carr has everything under the sun. If they don't have it, you don't need it.
Offline WideAWAKE
« Reply #13 on: August 27, 2022, 07:29:37 AM »
Also, any local bike dealer should have them.
« Reply #14 on: August 27, 2022, 10:04:10 AM »
If a standard copper washer wont seal you have a bigger problem
Offline slikwilli420
  • Master of Disaster
« Reply #15 on: August 29, 2022, 07:16:25 AM »
I bought a bag of either 25 or 50 from Amazon for like $10. I bought the small 6mm for the drain plug at the same time.
« Reply #16 on: August 29, 2022, 08:05:01 AM »
 Cut the ring off of an electrical crimp connector.
Offline craz1
  • CDA, Idaho
« Reply #17 on: August 29, 2022, 06:47:35 PM »
I buy solid copper seals from these guys. I use 6mm,8mm,10mm. But 20 of each and they will last a while.
https://belmetric.com
74 CB550,73 Z1900, 74 Z1900, 75 Z1900,
72 XS2650, 73 RD350, 2013 FJR1300, 84 XJ550 YAM
Offline alacrity
  • Ride, Optimize, Repeat
« Reply #18 on: September 01, 2022, 12:17:30 PM »
good suggestion -- they are out of the m6 kind needed for cb550 valve covers tho.
Offline Kenzo1979
« Reply #19 on: September 02, 2022, 04:05:36 AM »
I bought an assortment of metric copper washers off Amazon.  I used 8mm for exactly the job you're doing.  The only thing was the O.D. was slightly larger than the well, so I put a bunch of them on a bolt with a nut at the end and then knocked a mil off all the way around on a belt sander.  Only took a minute and now I have a handful that will fit.  Good luck.
--Kenzo
** 71 CB500, 74 CB550, 76 CB400F, 77 CJ360t **
