I have always considered the CB 500 the ideal middleweight bike; not too big or heavy, not too small. In the '70s, it was considered to be a BIG bike.
I agree. It's all about the weight/performance ratio. 50HP is plenty for me. IIRC the CB500 was the first 4stroke production bike that touched the 100HP/liter line, be it the HP in SAE and not in DIN
. Also I don't want my bike to weigh more than 200 kilo's.
And I like all the mods you made, except one: the red rear turn signal lenses. As I remember, in the UK they were not allowed, and had to be amber, ostensibly so that, when lit, they would not be confused with brake lights. Also, amber is better seen in foggy conditions, where it is critical being seen from the rear; here in the US, many model cars have red turn signal lenses, and, their worst application is when that bulb works in combination with the brake light.
You're spot on and I agree. Amber flashing indicators are better noticed. My front indicators still flash amber, but
extinct they're modestly neutral. I choose red lenses in the rear because I dislike amber. I always associate that color with cheap toys or scooters at a fairground. It would have been nice if they, in spite of their red appearance, would
also flash amber, but I don't know how to realise that.
@Ekpent. Lots of leaves which is exceptional. We had a very dry summer.
@Kevnz Paint on mine is original. It's called
Excel Black (NH-57). Yours in the pic is beautiful.
My model, the CB500K2-ED, aka CB500K2
GENERAL EXPORT was the last of the oldstyle CB500s. Assembled in 1976, it shares many parts with the CB5
50K2. If you study the parts list, you will see some parts underwent modification: gearbox (minor though), clutch adjuster, frontlegs, swingarm etc. Bike has done almost 140.000km. So far I didn't have to replace any fork seals, probably thanks to the harmonica rubbers. I've renewed the damper oil no more than 4 times max. I see no reason why you would do it more frequently. Clutch adjuster greased no more than two times, swing arm maybe 4 times, that is if I did manage to press it in
. If I didn't, it's been less
. Still no sign of wear. I have 4 new rubber boots (carb-head) ready in their packages, but I have no indication the originals leak. I change the oil every 3000-5000km* or every two years, which ever comes first. I don't do short rides. Oilfilter every second oilchange. Oil is not specified as JASO-MA. Actually, it's right on the edge. Never had the clutch slip. Clutch springs and friction plates were at the end of their lifespan at 75.000km and were replaced by genuine Honda parts. Most disappointing part however has been the camchain and its adjuster. I never seem able to do more than 50k with it. Costly! Primary chain has play, but I see no reason to replace. I know of someone who's bike at 220.000 km still had the original chain in. Front wheel bearings are still original, those in the rear have been renewed. Also I needed to replace the drive flange for a good second hand one. This because of the use of a socalled steamwasher which had removed essential grease. Don't use pressurized water! Splines of the kick arm shaft are worn. I think I've found the root cause and hope to publish on this soon.
Although the original rear shocks (5-stage on this model like the CB550K2) were not as bad as many say, I've replaced them nonetheless @ 50.000 by Dutch quality Koni's. They still serve well.
@Grcamna2 See OP, you may also be interested in reading:
http://forums.sohc4.net/index.php/topic,188492.msg2188254.html#msg2188254 and
http://forums.sohc4.net/index.php/topic,188492.msg2188271.html#msg2188271 I hope to publish more on the subject soon.
The latter on holiday trips.
