Hello Everyone,
Fairly new member here, been lurking pretty heavily over the past year. This community is amazing and incredibly helpful to so many, thought I'd share my situation, that I feel is now resolved....at least I hope so
Here's the story. I purchased an abandoned "barn find" k7 CB750, about a year and a half ago. She was in rough shape, sat outside in Colorado for about 21 years +(fortunately as the humidity is very low in CO as rust was minimal). Only had 17k original miles, but did a full rebuild on her over the winter, including a engine rebuild from Hondaman. Such a fun project, I have learned a ton and am enjoying so much of these bikes.
Since start up and break-in I have had periods where it seemed everything was going great and riding well, to periods of sudden change with idling and low rpm acceleration hesitating.
The cycle I would get into, referencing shop manual would be to pull carbs, thoroughly clean, check all seals, slow jet passage ways, check timing, set points, and reinstall, verify vacuum synch, and everything would run great for about a week or so...then go downhill quickly. Idling off choke was a problem, pretty ratty loud idle, occasional pipe backfire.
On this most recent teardown, I noticed for the first time that #1 spark plug was black while the three other cylinder spark plugs looked good. Here are the things I've learned and tried out that stand out from many threads here on the forum.
- For the 1977 CB750 the spec from Honda on float bowl height is 12.5mm..very much different from all the other bikes. I originally had this set to low (around 14.5 mm) and the slo-jet wasn't getting enough fuel, affecting the idle circuit. On the last rebuild, I raised to just over 12 mm to help with the stiff new valves from the carb rebuild kit. Chatted with Hondaman about this move and it potentially leaning the bike out further.
- Suspected vacuum leak. Original carb holder/insulator boots were stiff. I tried the carb cleaner spray trick to see if there was a leak, but never got any response...I believe it was a very small leak and changed as the engine would get hot. I think what was going on was when I'd finish a carb clean and reinstall, the engine and boots were cold and would seal up initially. After a week or so of riding around town, things would loosen up from the engine heat and introduce a small vacuum leak. Really wanted a new set from Honda, but I can't afford the inflated prices people are selling on eBay. All other stores online were out of stock on the aftermarket replacement boots, until recently. Purchased a set from partsnmore and arrived labeled (2) #1 and (2) #2 boots. Had some excess rubber flaps from the molding process, trimmed and smoothed the best I could inside the rubber "flute" or throat chamber. New clamps also installed. ...So this is what new flexible rubber is like
- The spec from Honda on the idle mix is 1.5 turns out, I'm currently sitting at 1.25 on all four cylinders...because of my altitude. I might end up richening a bit with the increased bowl float height to 12 mm, but will ride for a bit and see how she rides. (there's the very slightest lean pop on decelerations currently...probably a little lean, but will monitor)
After making the above adjustments, the bike started up great, but didn't have perfect throttle response (some bogging down) and needed some dialing in needed from some missing on cylinder #2.
-Reset points to .014, Points and condensers are new from partsnmore, replaced earlier in my troubleshooting. Timing appeared good, but while checking did notice an occasional stray spark in the advancer plate assembly. Uh oh, thought I had a complicated electrical issue. but came across an older advancer plate post and it turns out I had my condenser wire and points wire stacked up. This is how I found the original wires from the previous owner, and installed as found. (I forgot to take my own pictures and stole these from a previous post, as this was exactly my situation)
As left with proper condenser wire and coil wire orientation
Started up and no observed stray spark, checked timing...which had changed quite a bit. I had been checking and adjusting timing plenty on every carb clean and adjustment, but with the stronger spark, the timing moved (understandably) quite a bit. Verified vacuum balanced on all cylinders.
Took her out for a few rides this weekend and smiles the whole time, I can't 100% say as time will tell, but sure feel like I got her dialed. I've never had this throttle response and no issues at lower rpms. Such a joy to ride, can't wait for more adventure. I only hope these holders, hold up...pun intended. Really wish Honda would still make these.
