I just came back from the local salvage yard. they had three bikes with the triples and they were all cracked in the same location on the front round clamp area before the bolt. it could have been due to being age, being outside or the owner had cracked it and just did not notice.
I did not see any of the special D washers on any of them. but the area is so thin that maybe the washer was just lost over time.
it seems like a hard part to find and with prices ranging from 150 all the way to 750 on ebay.
I was looking at the aftermarket triples available and I would have to use clip ons, did not have instrument bezel holes for the original tach and speedo or they had mounts for their own instruments.
now owning a 350F, this was just a side project to see if it could be done and within tolerances to be safe.
my wife did say uh uh you are not putting that on my bike to test! LOL
this set once done with the reinforcement to the clamp area I will test out on the other set of forks to see if:
1)after clamping down to what the spec ft/lbs is, if it cracks
2)keep clamping down and up the ante of the ft/lbs until it cracks
dont know how many times it would take but would be interesting to find out.
I did not know if other metals that have a higher melting point might also be stronger for such a purpose.
I could even try this with steel and see how that goes with a 3d printer using pla lost casting process.
figure it would help someone else down the road
