Author Topic: Where to Connect Oil Pressure Gauge?  (Read 2551 times)
morseji1
« on: March 07, 2007, 08:06:30 PM »
Finally got the K0 I purchased checked over and the oil changed. The oil light is not working. Bulb is OK. Went ahead and started it for a couple of minutes after changing the oil. The oil tank pumped down to the correct level and I appear to be getting good return, so the oil pump appears to be working. However, until I get the oil light issue worked out, I want to see an oil pressure while I work on the bike. Where can I connect one, and what size/thread is the fitting?
Thanks,
Jim
Offline mrbreeze
  • Not your average
Re: Where to Connect Oil Pressure Gauge?
« Reply #1 on: March 07, 2007, 08:22:40 PM »
Not sure of the thread size but its a pipe thread I believe. There is a plug on the right hand side of your engine(above and to the rear of the points cover). Take out the plug. After getting a 90 degree fitting to screw the gauge into.drill & tap the plug in the middle of the hex. I don't recall the size but you should get everything together before starting the job.If you don't have a spare plug,you won't be able to start the bike till you get the hole you drill tapped and the gauge and fitting installed.
MEMBER # 257
morseji1
« Reply #2 on: March 07, 2007, 08:51:22 PM »
Thanks. I'll get a spare plug to drill and tap so that I can put the original plug back in once I know what the oil pressure is.
Offline starion88esir
« Reply #3 on: March 07, 2007, 09:18:31 PM »
I'm a visual learner, so here's a pic I stole off the forum.
71 CB175 - next project
76 CB750F - current project
Offline mrbreeze
  • Not your average
« Reply #4 on: March 07, 2007, 09:20:07 PM »
You don't need the 90 degree fitting if you aren't leaving the gauge on permenently.
MEMBER # 257
« Reply #5 on: March 07, 2007, 09:26:56 PM »
True, but why would you trust a dummy light with your engines safety?
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #6 on: March 07, 2007, 09:28:44 PM »
Is that seat still on there? ;D
Offline mrbreeze
  • Not your average
« Reply #7 on: March 07, 2007, 09:31:11 PM »
:D :D :D :D :D :D :D :D.........sick em Seaweb!!!!!!!!
MEMBER # 257
« Reply #8 on: March 07, 2007, 09:32:53 PM »
That seat does not affect my running issues...   no matter what you say.
:looks for a blue zodiac vinyl springer seat to replace the hang 2 seat: :o
Offline chung
  • Giddy Up
    • chungfucycles.com
« Reply #9 on: March 07, 2007, 09:33:28 PM »
I use the original location of the oil pressure lamp sensor for most oil sensor related attachments. A "T" can be added so that you can use the original lamp as well as a gauge. Hard lines prevail but it has to use a flexable connection at the fairing/steering head.
Having the oil temp/press gauges on the head with the rest of the gauges is a must for me. Hanging a gauge down buy my foot just doesn't work for me.
Member#2815
1971/76 CB750 Hack @970cc,
1975 CG750K
1970 CB350,
1972 YDS7, 250
1972 YR5, 350
1977 RD400,
1978 Piaggio Grande/Batavas HS50 Special
1981 XS650 Special II
Offline ttr400
    • ttr400 Projects and Billet parts.
« Reply #10 on: March 07, 2007, 09:38:10 PM »
Have a look on ebay, I have seen kits for the 750 complete with the plug ready to fit.  I think they are around $50.00.
Kevin
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
Offline jaym
« Reply #11 on: March 08, 2007, 06:33:39 AM »
i was buying one from a local guy for $75.00 and supplying the engine plug(still avail new from honda) for him to drill/thread, but this one from ebay is absolutely an awesome piece.  I have it sittiing on display in my garage just to look at until I need it for my next restoration.   http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=160091781639&ssPageName=MERC_VIC_RCRX_Pr4_PcY_BIN_IT&refitem=160082544903&itemcount=4&refwidgetloc=closed_view_item&usedrule1=CrossSell_LogicX&refwidgettype=cross_promot_widget
"accomplish what is important, not what is urgent"
morseji1
« Reply #12 on: March 08, 2007, 08:59:07 PM »
Thanks everyone. I have considered using the port where the sending unit is, but may go with the side plug. I am going by Honda tomorrow to pick up some parts I had ordered and may get an extra plug at the time. The unit on Ebay does look good.
