Author Topic: How do you know if you need new carb insulators/holders?  (Read 605 times)
Offline denward17
« on: September 30, 2022, 01:35:38 PM »
I am in process of cleaning bike and repairing  few items.
I was thinking of replacing my carb boots/insulators, but not sure if I need to.  I assume they are original to 1978.
They are pretty hard and hardly pliable, is that my clue?
Thanks
Offline Gary in NJ
Re: How do you know if you need new carb insulators/holders?
« Reply #1 on: September 30, 2022, 04:56:25 PM »
That’s a first clue (although new isolators are hard too). I’ve had old ones that worked, but I used silicone spray to ensure that the carb bank was able to easily slide on. Visible cracks or flairing at the end is a good reason not to reuse. The tell tale sign is a hunting or high idle that can’t be reasonably reduced via the normal adjustments.
‘76 CB550F Super Sport
Also in the garage; ‘98 Ducati ST2, ‘05 Yamaha FZ6N, ‘81 CB900, LS650 based Cafe Racer, DRZ400 based Street Tracker
Currently restoring the CB550F
« Reply #2 on: September 30, 2022, 05:09:13 PM »
yeah, a lot of times nice new boots just make things so much easier.  Old hard ones can be made to work, but they require more care.  Good clamps are important too.
