Author Topic: CB750 K5 Wiring Issue  (Read 546 times)
Offline JLeather
« on: November 07, 2022, 06:08:42 AM »
Running out of patience chasing a wiring issue on a K5.  Maybe someone has a new idea or a way to run this down.  I bought the bike as a non-runner and one of the handlebar controls was busted up.  I picked up a new matching set of stock replacement controls from 4into1 and wired the bike up.  Also, although it's a K5 I had a better set of K2 fork ears and signals so I wired them up so the signals do not have or use the park/running lights just the flashing lights. When I first got the bike together everything worked fine including all the indicator lights, the turn signals on both sides, etc.  On the maiden voyage I signaled for a right turn and the main fuse immediately blew (luckily I had a spare with me). Limped it home and started checking.  First I put another fuse in and tried the left signal; popped it immediately. Then I unhooked all 4 signals and tried again; fuse didn't blow.  Hooked the signals back up 1 at a time trying the signal switch after each one and the fuse never blew again (annoying) but after I got all 4 plugged back in they also didn't flash anymore.  I figured maybe the flasher had quit so I got a new one and changed it, still no flash.  So now when I signal left or right both signals on that side and the indicator light up, but it doesn't flash.  And I still never found any reason the signals would have been blowing my fuses. Anyone got an idea?
Re: CB750 K5 Wiring Issue
« Reply #1 on: November 07, 2022, 11:29:15 AM »
Typical faults of a flasher can, battery needs to be well charged or engine running for flashers to work
Online newday777
« Reply #2 on: November 07, 2022, 11:48:33 AM »
On the K5-K6 there is a jumper with brown/white that has a small black sleeve on one end that goes in the black lead and the br/wh on the other. Did you get that plugged in when you rewired it.
Stu
My current rides
Prior bikes....
Offline JLeather
« Reply #3 on: November 13, 2022, 07:47:48 PM »
Thank you all for the suggestions. There was actually a combination of mistakes, however the jumper was indeed one of them.  Oddly the Honda shop manual only shows that jumper for K6 and I have a K5, but I did need to add one.  I had all the lights and the ignition solely on the 15A fuse. The main cause of my fuse blowing, however, seems to have been the turn signal buzzer wire which I eliminated but had plugged into a ground by mistake.
Online newday777
« Reply #4 on: November 14, 2022, 12:48:50 AM »
Thanks for the update. Glad you found it and got it working correctly.
Stu
My current rides
Prior bikes....
