Bike: 1978 CB550
Had major leaks by the left sprocket cover, saw that the oil pump was leaking so I replaced all of the o-rings in there and that solved the issue.
After that Still noticed a very small leak from the stator cover and when I pulled it off a small pool of oil spilled out (no bueno). Traced it to the gallery plug. Cleaned it off and replaced the o-ring and pushed it back in. Warmed up the bike and took the stator cover back off and no leak but the gallery plug I’m guessing from the oil pressure was pushed back up flush with the stator surrounding area. I pushed it back in but my question is where is that gallery plug supped to sit? All the back in? Or a few mms out where it pushed to. Didn’t want to run the bike and have oil streaming out. Thanks in advance.
Pictures show where I pushed the gallery plug in. Orange stuff is I’m guess was previous owners “fix”
