Risk I repeat myself when lobbying for one way taking it apart.
Pistons runs free so only thing that bond cylinder and case together are the 2 dowel pins.
They have changed in lenght during the years.
Honda factory might have used slightly too long dowel pins that dug into case and cylinder when they slammed it together? The pins have sharp ends.
Maybe cylinder was seated with help of heavy nylon mallet before tighten the head that finalized it.
This engine is among the earlier numbers. Honda factory must have improved how to produce parts and assemble them during the years.
Try to bend cylinder off might cause damage.
So back to open lower case, crank with rods + pistons out.
A wooden u-shape wooden "tool" that can press sleeve 1 and 4 simultanously with help of a heavy hammer that does not need to hammer hard.
Heat gun that has warmed the case under the cylinder making the dowel pins to leave easier.
Open the engine for inspection must be OK for future value?
If cylinder never has been off, sealer gluing it together must cannot be the case here.
