Author Topic: My K8 re-conditioning  (Read 62788 times)
Offline denward17
Re: My K8 re-conditioning
« Reply #100 on: January 20, 2023, 12:01:09 PM »
Still waiting on machine shop activities.....
Decided to clean up and paint swing arm, check bushings and collar.
Collar is smooth on both ends.
Appears collar is in good shape, still had a lot of grease in there.  My measurements show 0.0008" clearance between phenolic bushings and collar, so I decided to leave for now.  I did order some Kibblewhite bronze replacement bushings, and may install those at a later date.
« Last Edit: January 20, 2023, 12:03:18 PM by denward17 »
« Reply #101 on: January 20, 2023, 12:18:12 PM »
That looks in good shape;use some quality grease that will 'hang in there' for a long while.
I'm still wondering what the best type of grease is;possibly boat trailer wheel bearing grease? I used that before on a Suzuki swingarm that has needle bearings and it was a blue color.
« Reply #102 on: January 20, 2023, 02:17:29 PM »
Does your swing arm have a std. grease nipple, centre underside? Take it out and make sure hole is clear. I replace it with a 45 degree nipple and loctite it in (very small drop on threads only) facing backwards. Much easier to get the grease gun on. Once assembled, pump in grease until all the air is out and it is packed. Do this before installing shocks and rear wheel so you can arc the swing arm as you pump. Get it packed and forget about it!
Offline denward17
« Reply #103 on: January 20, 2023, 03:37:18 PM »
yes, it already has a 45 degree nipple and has been cleaned out.  Will fill it up with grease during install...Thanks for the loctite tip.
« Reply #104 on: January 20, 2023, 04:59:18 PM »
It really helps to move it up and down and leave the cross bolt loose when packing it full the first time. The more you get in there the better!
Offline Alan F.
« Reply #105 on: January 20, 2023, 07:11:58 PM »
I remember Hondaman said to use only one kind of grease with his swingarm bushings, I'll check my private messages maybe it's there.
Nope, can't fine it in email or private messages. I think it's in the written directions he sent when return shipping my swingarm in 2008 but who knows where they've gone to. I bought the recommended grease then but I couldn't guess what it is called.
« Last Edit: January 20, 2023, 08:22:48 PM by Alan F. »
Offline denward17
« Reply #106 on: January 23, 2023, 02:34:39 PM »
Re-installed swing arm today and used a Sharpie paint pen to spiff up the alt. cover.
Should I do the circle?
UPDATE:
The sharpie pen paint is rubbing off after several days of drying, will probably clean up and use a different method.
« Last Edit: January 27, 2023, 08:16:57 AM by denward17 »
Online newday777
« Reply #107 on: January 23, 2023, 03:06:15 PM »
They didn't come with the circle painted, though some paint theirs.
Offline denward17
« Reply #108 on: January 23, 2023, 04:05:07 PM »
I think I will leave it like it is.......Thanks for the pics...
I'm struggling with my exhaust decision.........
I have a very nice set of the original pipes, but keep thinking of a 4into1 Delkevic, not sure why, but kinda want one...
« Reply #109 on: January 23, 2023, 04:18:30 PM »
Personally I really like the stock pipes, but it’s your bike, go with your gut!
What’s a “sharpie paint pen”? That looks really good.
« Reply #110 on: January 23, 2023, 06:20:09 PM »
I love the 4 into 4 stock exhaust also.
Offline denward17
« Reply #111 on: January 23, 2023, 06:35:56 PM »
oil based paint in a pen with a felt tip...
https://www.amazon.com/dp/B00WL2NM0K?psc=1&ref=ppx_yo2ov_dt_b_product_details
« Reply #112 on: January 23, 2023, 07:39:18 PM »
Thanks! I’ll pick one up.
« Reply #113 on: January 23, 2023, 08:43:04 PM »
Delkevic pipes are high quality and are far throatier than stock. You can always pick them up and try them for a while. I am betting you could easily get 1/2 of they cost back if you sold them used if you didn't like them.
The stock 4-into-4 is classic but no one who likes bikes is going to criticize you for running the Delkevic. Just clean up and prep the pipes for storage if you do pull them. It is either DonR or Erik who use Eastwood's exhaust paint designed for inside an exhaust system to help extend the life of these pipes. There are ways to give the inside of a set of used pipes a good cleaning prior to the Eastwood coating.
Then a good wax job after cleaning up the exterior and the pipes will store up nicely with no deterioration.
Humid environments can wreck pipes and cars where moisture condensate just activates any rust and acids...
David
« Reply #114 on: January 24, 2023, 06:38:36 AM »
I have a Hindle set on my Rickman project and what really impresses me is their weight. The whole thing weighs almost nothing!
« Last Edit: January 24, 2023, 02:36:21 PM by BenelliSEI »
« Reply #115 on: January 24, 2023, 07:17:08 AM »
Yes,
Hindle 4-2-1 is ultra light.
« Reply #116 on: January 24, 2023, 08:51:31 AM »
The Hindle cuts a large amount of weight and in my opinion is of better quality design than the Delkevic.
Offline denward17
« Reply #117 on: January 24, 2023, 09:09:46 AM »
Installed new throttle, choke and clutch cables today....
Little more cleaning of different items.
Cut some automotive heater hose to install on frame before engine installation.
Waiting on machine shop services...
« Reply #118 on: January 24, 2023, 01:55:04 PM »
+1 on the 4 into 4.  You can always buy aftermarket later...
« Reply #119 on: January 24, 2023, 02:40:51 PM »
Yes,
PeWe.... I’ll bet the entire Hindle weighs less than one stock pipe. It came attached to my last cb750F when I bought it and as I pulled it off, was super impressed.
« Reply #120 on: January 24, 2023, 04:33:03 PM »
People poo poo weight savings, but this is the real performance improvement of a 4-1.  Very little change in engine performance, but knocking 25 pounds off a 500  pounder immediately makes a noticeable improvement.
« Reply #121 on: January 25, 2023, 08:55:38 AM »
Yes, and I notice that the bike seems to be a little more responsive on the low end.
« Reply #122 on: January 25, 2023, 08:58:20 AM »
I keep all the old hand grips I cut off, they work well to protect the frame. 3/4” pipe insulation works too.
Offline denward17
« Reply #123 on: January 27, 2023, 08:19:08 AM »
Just FYI, the Sharpie paint pen is easy to use, but it appears after several days of drying, it can still be wiped off easily.
Will probably clean out and try some other method.  I did use a heat gun on it, but it just wipes off with finger pressure.
« Reply #124 on: January 27, 2023, 09:55:40 AM »
Thanks for that warning. I use a good enamel paint and a tooth pick, slow and painful! I want to save the tank badges on the S/C. I wonder if I could use the pen and then clear coat??
