Left my cylinders/new pistons at a different machine shop today. Talked with the guy that said "I do all the cylinder boring here, and have done a lot of motorcycle cylinders".
I gave him the target spec for clearance after honing is .0008", he said "sounds tight, but will do if that is what you want".
Hopefully will turn out ok, will find out I guess.
I think that's an encouraging response from the machine shop.
I used to live in Toccoa,Ga. I found a good machine shop in Athens,Ga. where I was seeing an Audiologist Dr. for my hearing.I brought a small single cylinder w/ new OEM Honda piston into the machine shop and specified a factory Honda clearance of "about .001" piston to cyl. clearance,no more" to the machine shop to which they said the same exact thing to me
They did the job and it turned-out great;I had plenty of compression and did a proper break-in and that little 2-stroke 50cc bike ran great with plenty of compression and power for a long time. I rode it from Toccoa,Ga. to Athens,Ga. a few times a week back and forth for a while as long as I lived in Ga. I was also getting my allergy shots down there,etc. Athens,Ga. is where Partzilla is, so getting Honda parts from them.
I rode that little bike at 25 mph(close to top speed & I'm 225lbs)the entire journey;a 1977 Honda Express
They did the engine machine work 'to my spec'
I was very pleased with the shop following my specified instructions.
