Author Topic: My K8 re-conditioning  (Read 21979 times)
Re: My K8 re-conditioning
« Reply #175 on: February 24, 2023, 04:22:45 PM »
Here is the spray I use, The can is at least 15 yeas old!
Yes,the Permatex company has had that spray for quite a while;it works well on valve cover gaskets,etc.
That's probably were I bought it for back in the 70s, and the oil pan.
« Reply #176 on: February 24, 2023, 04:25:03 PM »
I’m a fan. A very light coat, and let it totally dry before use. I spray both sides if I want a permanent seal, just the gasket for less aggressive grip. On engine side covers, I only do the outside. Gaskets stick to the cover and get used over and over.
« Reply #177 on: February 24, 2023, 04:25:19 PM »
I like using it on non-rubber porous gaskets where it might leak oil w/o it;I let it dry for a good while before installation.
Offline denward17
« Reply #178 on: February 28, 2023, 10:54:15 AM »
Installed head today, 2 - o-rings from Hondaman (between head and cylinder for oil pressure lines), the 8 - shortened dowels and new seals around them, and Vesrah head gasket (no sealant).
Torqued all head nuts to 11ft lbs., then 14 ft lbs.  Smaller 6mm bolts went to 7.5 ft lbs.
Will leave like this for a day or so and check torque gain.
What's the consensus on re-torqueing? Loosen them first or just re-torque from current status?
« Reply #179 on: February 28, 2023, 11:00:30 AM »
Always loosen 1st
« Reply #180 on: February 28, 2023, 11:37:04 AM »
Only tighten head by 14 ft lbs?
I tightened over 20 when I used stock studs and 836cc. 21-22 with heavy duty studs.
At least 18 ft lbs must be ok with a good torque wrench.
Offline denward17
« Reply #181 on: February 28, 2023, 12:59:55 PM »
^Thanks PeWe, I will recheck tomorrow at 14 before I do anything, then bump up to about 17.
« Reply #182 on: February 28, 2023, 01:37:27 PM »
Nice work! Your ahead of me, pistons went on the rods today.
Offline denward17
« Reply #183 on: March 01, 2023, 11:18:55 AM »
I re-checked a few at 14 ft lbs that I left since yesterday, a couple would go more.
So I loosened all of them in reverse order and did a 4 step torque, 10, 12.5, 14.5 and final of 18 ft lbs.  Will leave overnight and check again tomorrow.
Spent time cleaning (with brake spray cleaner) all top end components, especially the oil jets and oil holes in the cam towers.
Plan is to install cam towers/cam tomorrow.
Anyone use Blue Loctite on cam tower nuts/bolts?
Is this Permatex liquid sealant ok to use for pucks?
« Last Edit: March 01, 2023, 12:47:57 PM by denward17 »
« Reply #184 on: March 02, 2023, 06:55:42 AM »
I would not use that. Honda Bond is a great liquid sealer I prefer for the pucks. Loctite makes a very similar product that I intend to try out. Also, poke down through all the tower bolt threaded holes in the head. Most are blind holes, but in some heads, they are drilled and tapped right through, into the air gaps in the casting. These can also drool a bit of oil through. A small dab of the sealant on those bolt threads is a good idea too!
Offline denward17
« Reply #185 on: March 02, 2023, 09:31:15 AM »
Going together....slowly....
Offline denward17
« Reply #186 on: March 02, 2023, 09:32:39 AM »
cam is in and timed....
« Reply #187 on: March 02, 2023, 11:37:09 AM »
Cam sprocket bolts need blue loctite or similar brand with same strenght. Not harder.
Tighten with loctite when cam timing is berified to be correct.
Rotate engine with cam chain tensioner mounted. Adjusted, release and tighten at 15* ATDC. 1:4 Spring tower has just passed case mark
I have used high temp silicone under the pucks the last times.
Work fine, not as rinny as Permatex Aviation no 3
« Last Edit: March 02, 2023, 11:43:21 AM by PeWe »
« Reply #188 on: March 02, 2023, 11:54:31 AM »
We are living parallel lives! Put assembly lube on each cam lobe and the rocker pads too.
Offline denward17
« Reply #189 on: March 02, 2023, 12:01:36 PM »
Yes on Blue Loctite, using HondaMan's book, helps a lot.
Offline denward17
« Reply #190 on: March 02, 2023, 12:02:14 PM »
Yes, used a lot of assembly lube on everything...
Offline denward17
« Reply #191 on: March 02, 2023, 12:03:18 PM »
All valve clearances adjusted, all intakes @.003" and exhaust are .004".
Valve cover going on soon.
« Reply #192 on: March 02, 2023, 12:38:00 PM »
Great progress with quality parts.
« Reply #193 on: March 02, 2023, 06:22:53 PM »
Just a note. If you remove the exhaust studs, you will have a much easier (well, a bit easier) time putting the engine back in the frame. I also push on a piece of 1/4” fuel hose, split down one side, to the top fin on the head. Saves the frame paint......
Offline denward17
« Reply #194 on: March 03, 2023, 12:19:58 PM »
Benelli, I tried to remove a couple of exhaust studs and they didn't budge, was concerned I would break one so am leaving them in, but I wrapped the frame with old cut up heater hoses, if I scratch it here and there no big deal, I can touch it up.  This is not a concours bike.
Almost ready to go in......................hopefully early next week.
« Reply #195 on: March 03, 2023, 01:56:48 PM »
Looking good  8)
« Reply #196 on: March 03, 2023, 03:26:40 PM »
Smart move. No point in creating a problem we’re there isn’t one!
« Reply #197 on: March 03, 2023, 07:56:08 PM »
denward17,that finished engine assembly looks Great  8)
I hope you find a person whom you can trust to help you lift it into the frame.
A few members have set-up their engine over on it's side,then installed the frame over the top of it;either way,a helper would be nice.
Offline denward17
« Reply #198 on: March 04, 2023, 10:58:33 AM »
My son (David) and grandson (Calvin) came over today to assist with the engine install.....she is in....
Will continue next week.......
« Reply #199 on: March 04, 2023, 12:01:01 PM »
Yeah buddy  ;)
I like that a Lot better than struggling around by myself  :)
