Author Topic: I'm 206 digits between engine and frame numbers. Can you beat that?  (Read 645 times)
Offline Doobie
I have a CB750K and the frame is 2000494 and the engine is 2000700. 206 digits apart. How close are you to a perfect match?
You only go around once in life so it might as well be on a motorcycle.
CB550K4
CB750K2
CB750K2
CB750K6
CB750K6
CB750K7
CB750F3
CB900F2
Offline grcamna2
Re: I'm 206 digits between engine and frame numbers. Can you beat that?
« Reply #1 on: November 24, 2022, 04:10:46 PM »
I like that  :)
Seems to me that plant production at Honda was very 'in synch' the day they installed your engine into the frame;they rolled a good,close number engine assembly up to your frame.  ;)
« Last Edit: November 24, 2022, 05:13:12 PM by grcamna2 »
« Reply #2 on: November 24, 2022, 05:09:00 PM »
 I have 14,100 and a blank engine pad. Another bike has a k1 engine and a blank frame. Both were replacement parts. Honda should have supplied dealers with number stamps.
Offline grcamna2
« Reply #3 on: November 24, 2022, 05:15:12 PM »
Don,does ILL. require both Frame V.i.N. frame number And engine number to register it and put it into the system ?
Offline JohnnyL
« Reply #4 on: December 15, 2022, 02:02:14 PM »
My 78750 has
Engine 750E-3023979
Frame.         2823971
I believe thats 8!!
Online denward17
« Reply #5 on: December 15, 2022, 03:14:19 PM »
My '78;
CB750E3006300
CB750K2806186
Offline Handlebar
« Reply #6 on: December 15, 2022, 03:28:13 PM »
My 78f is 2070 frame 2090 engine.
« Reply #7 on: December 15, 2022, 03:53:17 PM »
 No, I've never had anyone from Illinois look at my numbers except when I needed a VIN check to get a title. Even then he only looked at the frame.
Offline grcamna2
« Reply #8 on: December 15, 2022, 07:04:36 PM »
I moved here to Ca. and noticed when I registered my bike and got it into the Ca. DMV system,they recorded the engine # and it's on my registration also.  :D
« Reply #9 on: December 16, 2022, 12:09:54 AM »
i sourced a used cb500 engine from Canberra,and one from Brisbane years ago,they were ten engine numbers apart,so they went down the line almost side by side and got split up and shipped to Australia miles and miles apart for years and years,then both ended up at my place.
Online CycleRanger
  • No comment about being an
« Reply #10 on: December 16, 2022, 04:23:04 AM »
This is an interesting subject.
With enough data you could track the deviation between frame and engine as each model year production progressed and graph it out.
Offline Doobie
« Reply #11 on: December 16, 2022, 05:17:56 AM »
My 78750 has
Engine 750E-3023979
Frame.         2823971
I believe thats 8!!
Love it. I doubt anyone will have closer numbers.
CB550K4
CB750K2
CB750K2
CB750K6
CB750K6
CB750K7
CB750F3
CB900F2
« Reply #12 on: December 16, 2022, 06:07:59 AM »
1029696 is the frame, 1029049 is the engine number = 647.
Offline stocky
« Reply #13 on: December 16, 2022, 07:31:11 AM »
77 CB750k
« Reply #14 on: December 16, 2022, 09:13:35 AM »
 My sandcast has a 400 number spread, a member here had one that was a few bikes away and it also had a similar spread. Apparently, a batch of newer engines got dropped off on the loading dock that day.
« Reply #15 on: December 16, 2022, 09:28:49 AM »
  Caution; car story,
  I got a tour of a car collection that had four 426 hemi cars, the owner flew in the Mopar certification guy to confirm originality and document them. After returning with lunch the cert guy asked if he purchased two of the cars from the same person, apparently at some point the two cars had their engines swapped. They were bought in different states from different owners and yet ended up in the same collection, parked side by side.
  Engines were later swapped back and cars are numbers matching again.
Offline tool14
« Reply #16 on: December 16, 2022, 09:32:47 AM »
My 78750 has
Engine 750E-3023979
Frame.         2823971
I believe thats 8!!
                          your numbers are 200,008 apart
Offline JohnnyL
« Reply #17 on: December 17, 2022, 11:29:05 AM »
Tool14 - You can’t subtract the frame from the engine
1978 engines start 3000001 and the frames start at 2800001.
My engine was the 23,979th off the line and my frame was 23,971st off the line.
They met up on that faithful day (12 /77) on the assembly line!!
John
« Last Edit: December 17, 2022, 11:30:57 AM by JohnnyL »
