Author Topic: Gas cap latch installation  (Read 605 times)
Offline toma
« on: December 07, 2022, 07:25:01 PM »
I am having trouble getting the latch spring compressed so that I can push the pivot through it and the mounting hole. Any successful ideas appreciated. Just finished painting the tank and don't want to scratch the new finish. Thanks -  Tom
Re: Gas cap latch installation
« Reply #1 on: December 07, 2022, 07:44:20 PM »
I usually wait until the new paint is well cured, then lay some cardboard (like the kind from the back of a pad of paper) around the filler neck so I can stuff that dang thing back together again. Then I can just tear away the cardboard afterward, because I just cut a little form-fit hole for that bracket and lay the cardboard over it.
I only wish I had done that after the FIRST time I painted a tank...
« Reply #2 on: December 08, 2022, 01:42:39 AM »
Good idea! Definitely don't want to scratch the paint!
« Reply #3 on: December 08, 2022, 06:53:39 AM »
I've used painters tape around the opening to prevent any accidents to the paint.
Offline toma
« Reply #4 on: December 08, 2022, 01:08:46 PM »
Yes the cardboard is a good idea.
But I was hoping that someone had thought up a good way to compress that little spring and make the install easier.
« Reply #5 on: December 08, 2022, 02:17:46 PM »
 I remember it being a challenge but not a good tip on how to do it. It seems like I held the spring in place and pushed the pin and latch into it. Do it in a clean area so when the spring goes into orbit you can find it again.
Offline toma
« Reply #6 on: December 08, 2022, 06:02:58 PM »
My shop seems to have a few Black Holes where things go never to be seen again.
« Reply #7 on: December 08, 2022, 06:23:24 PM »
Go to a dry cleaner and get a clear plastic garment bag. Put the tank in the bag, reach in the bag and preform the magic to avoid the Black Hole......
« Reply #8 on: December 17, 2022, 02:42:08 PM »
There's a good idea!
Now, what happened to my local dry cleaner...?
