Author Topic: Leak down test questions  (Read 877 times)
Offline denward17
« on: December 19, 2022, 04:57:02 PM »
CB750K 1978
I purchased a cheap Amazon leak down test kit, and the gauge that showed percentage would not go to zero.  Stayed up to around 40% before connecting the hose to the cylinder.  I didn't hear any air leaks so I assume the gauge is faulty.
Needless to say I do not put any trust into this gauge.
The engine is out and cold. I hardly heard any air when connected to #2 or #3.  Just a little on #1, but the air noise increased when connected to #4.
I took the valve cover off and checked the tappet clearance to make sure they were not to tight on any cylinder, all clearances were in the ball park of EX .08mm and IN .05mm.
Is it normal to hear air noise when doing a leak down test?
Can I use the regulator from my air compressor to perform the test and get readings?
Or do I just bite the bullet and buy a better leak down test kit?
Any ideas appreciated.
Re: Leak down test questions
« Reply #1 on: December 19, 2022, 05:15:13 PM »
A proper leak down test is a fairy complicated thing to do, with connector to cyl open gauge should read 100%, with connector to cylinder blocked off should be zero%.
With cylinder at tdc of compression and leak down kit connected listen for air at inlet port, exhaust port and engine breather, or with cover off, valve gear.
Repeat this for each individual cylinder and compare % of leak on each cylinder, you are more looking for a variation than a specific number.
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: December 20, 2022, 06:12:22 AM »
The % gauge should not be at 40% unless the end fitting is leaking. Does it zero when not in use? I assume it’s not leaking when connected? What does the leak down gauge read when connected? Even higher?
You could always pop the face of the gauge and often the pointers are just a push on fit. Set to zero with a drop of glue. See how they work now?
« Last Edit: December 20, 2022, 06:16:05 AM by BenelliSEI »
Offline denward17
« Reply #3 on: December 20, 2022, 07:22:54 AM »
So I tried again this morning, and discovered the pressure from the compressor had to be set to 100psi before the % gauge would go to zero.
With this setup I discovered some bad things, #1, #3 and #4 all had readings near 40% leakage.
Number 4 especially had a bad exhaust valve leak, it was near 80/90%, and I could hear / feel air out the exhaust port.
Arghhh, didn't want to pull the head, looks like I need to now.
« Reply #4 on: December 20, 2022, 08:08:14 AM »
 If your valves are closed and the rockers were at zero lash it should be a lot better than that. My 836 read 4% on a good gauge but still smokes like a 2 stroke. I like to do a warm engine leakdown test as well as a cold one but that's just me.
Offline Flyin900
« Reply #5 on: December 20, 2022, 11:33:29 AM »
Just to confirm. You are setting and testing each cylinder at TDC individually and confirming that there is valve lash play on both valves on that test cylinder before the test? Any other setup will result in incorrect readings.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
« Reply #6 on: December 20, 2022, 11:34:53 AM »
Leakdown will not tell you if stem seals are shot or guides worn, only that valve seats so you can get a good reading but still smoke
Offline denward17
« Reply #7 on: December 20, 2022, 12:08:09 PM »
Yes, testing at TDC on each cylinder and making sure there is play in valve lash.
Now I have the cam out and just retorqued the head to 20 ft lbs.  There is no mention of the 5 6mm bolts under the pucks and on the front of the head near the chain tunnel, do these get torqued as well?
There was movement on about 3 bolts near where the oil leak was coming from.
Going to perform the leak down test again after torqueing.
Offline BenelliSEI
  • 1969 cb750
« Reply #8 on: December 20, 2022, 12:36:00 PM »
Good plan!
Offline denward17
« Reply #9 on: December 20, 2022, 01:04:13 PM »
Another test completed:
Cam out, head retorqued (except the bolts under the pucks)  Is there a torque value for them?
Number 3 was the best at around 20%, Number 1 and 2 were about 35% and number 4 was just over 50%
Numbers did improve just a little after re-torque.
What to do now, leave it, or take head off for valve job?
Offline denward17
« Reply #10 on: December 20, 2022, 01:05:42 PM »
more pics; pucks were puckered to the inside for some reason.
« Reply #11 on: December 20, 2022, 02:35:05 PM »
50% is too much, pull it down and inspect it now whilst its out
Offline denward17
« Reply #12 on: December 20, 2022, 03:05:14 PM »
That's what I am thinking as well, as much as I hate to admit it.
« Last Edit: December 20, 2022, 03:06:53 PM by denward17 »
Offline Tracksnblades1
« Reply #13 on: December 20, 2022, 05:01:15 PM »
Well done  dw17..
Make sure your readings repeat consistently..
Then follow the other advise…
Now you Know….!
Age Quod Agis
Offline BenelliSEI
  • 1969 cb750
« Reply #14 on: December 20, 2022, 06:14:02 PM »
Do you hear where the leaks are? Should be loud from the crankcase (rings) or the intake or exhaust port (valves). If that engine has not run for ages, the valves that were open will have corrosion on the seats..... pulling the head and giving them a little relapping will probably do it.
Offline denward17
« Reply #15 on: December 20, 2022, 06:25:31 PM »
Most of the air leaks I heard sounded like they were from the valves.  I could not distinguish if air was coming from crankcase.
I guess I could hook my hoses again and try to listen more carefully.
Would I be stupid if I don't do rings?
« Reply #16 on: December 20, 2022, 08:09:39 PM »
No, but you would be if you didnt pull cylinders and look
« Reply #17 on: December 21, 2022, 03:56:43 AM »
The rubber pucks behave like that, dome downwards probably expand by heat. They cannot go the other way.
I usually flip them next time. If rubber is still soft.
+10 years old might need a change though.
Offline BenelliSEI
  • 1969 cb750
« Reply #18 on: December 21, 2022, 06:04:22 AM »
What’s the mileage?
Offline denward17
« Reply #19 on: December 21, 2022, 06:52:40 AM »
What’s the mileage?
Mileage is 22k.  Another test this am with a hose to my ear.  Heard quite a bit of air noise at 3 exhaust valves, and all had air noise down the cam chain tunnel and the oil tank breather port on the back of the block.
I guess that points to rings as well.
BTW, with the cam out, I'm not rotating the pistons to TDC, but that should not matter, correct?
« Last Edit: December 21, 2022, 06:54:24 AM by denward17 »
« Reply #20 on: December 21, 2022, 08:26:45 AM »
No cam, all valves closed
« Reply #21 on: December 21, 2022, 08:32:57 AM »
A worn cylinder bore no longer has straight sides.  Part of the test is for this type of wear.  And for that, the piston must be at TDC.
Offline BenelliSEI
  • 1969 cb750
« Reply #22 on: December 21, 2022, 09:00:54 AM »
What’s the mileage?
You can “tap” the exhaust valves open and closed a few time to try and seat them a bit better. Make sure the pistons are down in the cylinder you are tapping the valves.
« Reply #23 on: December 21, 2022, 09:03:53 AM »
 My experience has been if I pull the head, I usually disturb the cylinder base gasket. That leads to pulling the cylinder which leads to new rings. I learned to put rags around the rods because I'll usually drop a piece of something through the crankcase holes.
 I never understood the process by which rings become unusable when they are separated from their cylinder but that is standard practice.
 An engine that has sat may have carbon or even a bit of light rust that can wear away when running. Pitting however will not heal.
Offline denward17
« Reply #24 on: December 21, 2022, 09:06:06 AM »
What’s the mileage?
I tried tapping the top of the valve with a rubber mallet lightly, it did help with the readings, but they are still bad readings.
