Author Topic: Tire Load Index Rating  (Read 414 times)
Offline Ellz10
  • ZZ
  • Knowledge is Power
« on: January 02, 2023, 10:33:52 PM »
So it's now around the time I should start to look for tires for my bike. 77 K7, shaved about 25 lbs off total. Stock dry weight states 508 lbs. With me and gas and oil, around 730 lbs. Load Index rating puts me needing 69 or 70. I've found it's difficult to find an excellent tire with my needed load index, and even more difficult to find both tire sizes I need made from the same company (though I don't mind if they're different). Am I able to go any lower or am I asking for trouble?
« Last Edit: January 02, 2023, 11:28:52 PM by Ellz10 »
Re: Tire Load Index Rating
« Reply #1 on: January 03, 2023, 03:04:28 AM »
How much weight to carry on a CB750 has been discussed before so this thread may be helpful:
http://forums.sohc4.net/index.php?topic=115333.0
From my own experience riding a CB750 2-up thousands of miles weight on a CB750 is a non-issue. For those trips I used Bridgestone BT-45 tires though would recommend Avon Roadriders also.
I also found this useful
https://fortnine.ca/en/motorcycle-tire-load-capacity
Offline Ellz10
  • ZZ
« Reply #2 on: January 03, 2023, 08:10:36 AM »
That's a good read, thank you.
Now this may sound dumb, but the way I understood the article, the weight distribution isn't always equal.50/50 to each tire. With that being said, would I be safe in assuming I can put a 69 or 70 Load Index Rated tire in the rear and be okay with putting a 66 I the front?
« Reply #3 on: January 03, 2023, 05:36:24 PM »
I put a 57 on the front - absolutely fine 2-up as mentioned.
BT-45
SKU: 300638
Tire Size: 100/90-19
Rim Size: 19
Load Rating: 57
Speed Rating: H
Tire Application: Touring
Part #: 001029
As Fortnine/Ryan mentions in the link above:
"load your bike according to the motorcycle manufacturer's guidelines; not according to the load indexes on your tires."
