Author Topic: CB750 factory harness join  (Read 662 times)
Offline JohnnyL
« on: January 08, 2023, 08:01:50 AM »
Hey folks, is this join factory or has someone buggered with the harness?
Thanks
Johnny
Offline BenelliSEI
  • 1969 cb750
Re: CB750 factory harness join
« Reply #1 on: January 08, 2023, 08:04:30 AM »
Where do they run to? Don’t look stock to me.
Offline JohnnyL
« Reply #2 on: January 08, 2023, 08:22:05 AM »
The red and green wire is split and go here.. not sure what they are off hand.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #3 on: January 08, 2023, 08:43:12 AM »
Sure looks non-stock to me.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline jlh3rd
« Reply #4 on: January 08, 2023, 09:38:10 AM »
usually when honda ran two wires (or more) from one wire, they used a multi female  plug surrounded by a clear plastic covering...
looks buggered to me...
« Reply #5 on: January 08, 2023, 09:52:19 AM »
Green red should be starter safety circuit and should not connect to yellow red which is starter solenoid or starter button depending on year so i would hazard guess its been buggered about with to bypass starter safety circuit, and not that well either.
Honda do do that sort of connection in the loom for ground(green) and sometimes power(black) but its much tidier
Offline newday777
« Reply #6 on: January 08, 2023, 10:24:12 AM »
Definitely not original honda parts or connections. See the black electrical tape? That is the sign along with the black box.
BTW.  When asking for help like this please include full information of what "750" you are asking about so there's no question needed to be asked of you
Stu
My current rides
Prior bikes....
Online scottly
« Reply #7 on: January 08, 2023, 12:05:18 PM »
That is a factory crimp connection as used in the stock harness, usually wrapped in electrical tape. ;) The "black box" is a diode, which replaced the Starter Motor Safety Unit starting in '77. The yellow/red and green/red wires connect to the small wires on the starter solenoid.
« Last Edit: January 08, 2023, 12:08:23 PM by scottly »
Offline Nurse Julie
« Reply #8 on: January 08, 2023, 12:47:36 PM »
Yes, that is a standard from the factory Honda crimp. But, you can buy those crimps anywhere, so someone may have replaced / repaired it in the past. .
Trust me I'm a Nurse, I promise it won't hurt....much
« Reply #9 on: January 08, 2023, 01:25:54 PM »
Still say its not tidy enough for original Honda
Offline Doobie
« Reply #10 on: January 09, 2023, 02:47:30 AM »
I'm with you. I've never seen any wiring that looked like that on any of the Honda CBs I've owned.
You only go around once in life so it might as well be on a motorcycle.
CB550K4
CB750K2
CB750K2
CB750K6
CB750K6
CB750K7
CB750F3
CB900F2
Offline jlh3rd
« Reply #11 on: January 09, 2023, 08:41:09 AM »
from a wiring harness....factory crimp
Offline jlh3rd
« Reply #12 on: January 09, 2023, 08:42:19 AM »
from a Honda Cl 70....factory soldered joint....
just fyi....
