Author Topic: UNSOLVED MYSTERY: 1977 Honda cb750K  (Read 3008 times)
Offline jlh3rd
Re: UNSOLVED MYSTERY: 1977 Honda cb750K
« Reply #25 on: January 10, 2023, 01:33:38 PM »
I also pulled an original Owner’s Manual from under the seat, on my K7. Guess what? You can clearly see the bolt on bracket for the front, left side mount......
and the honda guide book shows the '77 with the bracket....and the '78 with the bung...
Offline jlh3rd
« Reply #26 on: January 10, 2023, 01:40:42 PM »
any engine removal sections in those service manuals?
« Reply #27 on: January 10, 2023, 01:43:26 PM »
Will a K8 flat style motor mount bracket work in place of that special factory bracket on the K7 ?
Nope. My K8 has a welded lug on the frame there (identical to 1969-76 cb750K) and the single bolt just passes through the frame lug and the engine.......
John,does the K7 engine have more ease of removal and installation when sliding the engine out from the left side of the frame with that separate motor mount part removed,compared to the other model/year CB750's ?
I honestly can’t remember. But, looking at it it probably does. It still had to come out on the right side, but I think there was more “rocking room” than the others. I usually grind the flange off the one on the right side for a little extra space too.
« Reply #28 on: January 10, 2023, 01:44:10 PM »
Well that’s interesting. Different than the Owner’s Manual photo.....
Offline jlh3rd
« Reply #29 on: January 10, 2023, 02:14:57 PM »
I've got a 550F honda brochure....with the clocks being for the 750's......so, go figure.....
« Reply #30 on: January 10, 2023, 05:01:24 PM »
Does the tach read correctly?
Offline jlh3rd
« Reply #31 on: January 10, 2023, 05:26:06 PM »
for the 750 it does...140 mph speedo ............it won't let me enlarge the pic.....
brochures in the shed....it's cold....don't feel like going out....
if ya can't see it....I'll do it tomorrow
« Last Edit: January 10, 2023, 05:36:21 PM by jlh3rd »
Offline jlh3rd
« Reply #32 on: January 10, 2023, 05:34:17 PM »
there
« Reply #33 on: January 11, 2023, 07:54:54 AM »
I have a 9/77 and a 12/77 frame and they both have the same welded bung as the pre77 frames had (-76) so no help on the mystery......
Offline jlh3rd
« Reply #34 on: January 11, 2023, 10:25:14 AM »
no,...you have a 1978 model...isn't that what the "78" is that I see ?....
unless I'm misunderstanding what you're saying....
we're not talking frame manufactured dates , we're talking model years.....
It is only the 1977 model 750's that have the bracket......you have a 1978 model....
but no help....
« Last Edit: January 11, 2023, 10:30:14 AM by jlh3rd »
« Reply #35 on: January 11, 2023, 10:29:40 AM »
and, as a side note, I've always thought that the frame date is the date they manufactured the frame.....not the bike...and your pic supports that theory.......
but no help....
Yes. I was replying to John(reply #23) as we were discussing dates on early K8 frame possibilities.....
« Last Edit: January 11, 2023, 10:32:27 AM by newday777 »
Offline jlh3rd
« Reply #36 on: January 11, 2023, 10:31:54 AM »
wonder what frame dates are on the '77's..
« Reply #37 on: January 11, 2023, 11:15:37 AM »
Do the frame dates start on the month of June( 6/76' ?) and end on the month of May( 5/77' ??) or possibly Stu would know for sure,as he was Parts Manager at the Honda dealership ?
« Reply #38 on: January 11, 2023, 11:25:52 AM »
I didn't learn the dates back then. I've gleaned a lot from the forums that I had missed in my early days......
Reading the charts, some of the years had different start dates, some years aren't listed....
« Reply #39 on: January 11, 2023, 11:33:57 AM »
I understand.
Stu,for instance on the i.d./V.I.N. badges on different models,I didn't see the large letters and numbers describing "1978 Model" until about the late 70's ?
Offline Bankerdanny
  • Endeavor to persevere
« Reply #40 on: January 11, 2023, 11:42:46 AM »
Honda did a couple of one year things to frames. My '76 F frame has nuts welded to the neck right in front of the VIN plate that I assume were for a fairing that they planned to offer but didn't. The nuts are gone from the frame on my buddy's '77 F.
« Reply #41 on: January 11, 2023, 11:50:50 AM »
I understand.
1977 was the change to large font model year
Offline Laids
« Reply #42 on: January 11, 2023, 12:14:09 PM »
I posted this question 2 years ago when I was given 2 750’s one was a 77. Noticed the 77 motor mount was peculiar. :o
« Reply #43 on: January 11, 2023, 12:46:06 PM »
Do you have the manufacture date of yours?
« Reply #44 on: January 11, 2023, 01:11:56 PM »
Here is a 1977 K7 a friend has that has the removable bracket.  Manufacture date is 8/76
Offline jlh3rd
« Reply #45 on: January 11, 2023, 01:20:27 PM »
if you haven't followed this thread......It's not only peculiar.....you can't order it....it doesn't "exist"...
Offline jlh3rd
« Reply #46 on: January 11, 2023, 01:31:36 PM »
not to derail....it appears you are right...there's two "nubs" ?? showing on the '76f frame (bottom)and nothing for the '77F frame (top).....so it shows up on the parts page...
....but there is no bracket on the '77 K's parts page, just the bung...
Offline Laids
« Reply #47 on: January 11, 2023, 04:02:04 PM »
I passed that bike on. I took a pic of the engine vin but not of the frame vin but both were 27…..
Offline jgger
« Reply #48 on: January 11, 2023, 04:02:49 PM »
You guys realize those are just cheap Chinese knock offs and they ain't worth anything. Send me picks of what you got and I might be able to come up with maybe $ 100.00! 🙈🙉🙊
« Reply #49 on: January 11, 2023, 04:12:40 PM »
 My 77 has the two-sided mount also. it seems like it would be stronger.
  I do that to the right rear upper mount on the performance bikes using a late and early mount with a late type bolt. Once I welded a spacer tube between two flat ones.
