Author Topic: UNSOLVED MYSTERY: 1977 Honda cb750K  (Read 5391 times)
Re: UNSOLVED MYSTERY: 1977 Honda cb750K
« Reply #50 on: January 11, 2023, 05:02:43 PM »
 My friend that builds race cars had a goal of making his chassis as stiff as possible. He did, but I think they learned the cars needed some flex to work their best.
« Reply #51 on: January 11, 2023, 05:21:06 PM »
For traction during stress ?
« Reply #52 on: January 11, 2023, 05:25:29 PM »
You guys realize those are just cheap Chinese knock offs and they ain't worth anything. Send me picks of what you got and I might be able to come up with maybe $ 100.00! 🙈🙉🙊
If anyone needs this ‘77 cb750K engine mount bracket (the one that appears not where and no part number) I do have one..... no idea where it came from!
Offline jlh3rd
« Reply #53 on: January 11, 2023, 05:50:23 PM »
neither does Honda🙄
Offline Laids
« Reply #54 on: January 11, 2023, 05:56:16 PM »
[/quote
I sold the 77 basically in pieces, I told the buyer, don’t lose the mounts
« Reply #55 on: January 11, 2023, 05:57:15 PM »
I bought a K7 from an estate (the widow) in Colorado Springs, circa 2007, and rebuilt it: the engine had been hit on the right side at the points cover by her husband's car in their garage, and sat for 20+ years after because it sheared off the spark advancer (basically it ruined the crankshaft) without damaging the engine cases. When I pulled that engine I took pictures of everything so I could document the "rebuild" to the guy who bought it later, but it did NOT have that fancy left lower bracket. It DID have a bent frame, so I had to strip the whole thing and then use hydraulics to straighten it ('twas a gamble, if it didn't work I was going to be out $500 for the bike), and the left-side frame was bent outward (toward the left) at that mount, about 3/4". That frame, though, was just like the '76F1 that I also had at the time, which also doesn't have that fancy thing! It was pretty simple to straighten, in the end, and worked out with wheels in align, and the works.
It had a Vetter, so I had a soft spot for it...
It had a build date of 10/76 on the steering head, making it a very early K7.
So, I don't have any clues about this, either!
So I’m guessing the 77/78k shared the same rake angle and longer swingarm with the 76F1…?
Offline jpdevol
« Reply #56 on: January 11, 2023, 09:44:02 PM »
'76 750A fiche from CMSNL.COM
says p/n is 50351-393-000
...and also here: https://www.partssweden.se/honda-cb750a-750-hondamatic-1976-usa-cb750-four/frame
« Reply #57 on: January 11, 2023, 11:03:49 PM »
Is it possible Honda used up excess 750A frames cos they didnt sell well
Offline jlh3rd
« Reply #58 on: January 12, 2023, 04:56:04 AM »
got it.....yep...to me, the fact it's not on the parts list is weird.....
the '76 750A is the closest I've seen...but still one sided...
that is not it...
already posted that. The 750A is one sided....the '77K is a two sided bracket....
« Last Edit: January 12, 2023, 05:00:27 AM by jlh3rd »
Offline jlh3rd
« Reply #59 on: January 12, 2023, 04:57:16 AM »
'77K
Offline jlh3rd
« Reply #60 on: January 12, 2023, 04:57:54 AM »
'76 750A
Offline jlh3rd
« Reply #61 on: January 12, 2023, 05:13:21 AM »
two different part #'s
« Reply #62 on: January 12, 2023, 11:27:13 AM »
Checked the frame plate on my K7 today (with the “no part number” bracket). March 1977 build date, cb750K-2725117.
Offline CycleRanger
  • No comment about being an
« Reply #63 on: January 12, 2023, 11:34:56 AM »
'76 750A
Hmm, now that's interesting.
I wonder if some of the 77K frames were made in the same factory as the A bikes.
« Reply #64 on: January 12, 2023, 03:57:03 PM »
Looks like some ‘77 frames have the lug too! Spotted this one today on FB and it clearly shows the “regular” mount.
Offline jlh3rd
« Reply #65 on: January 12, 2023, 05:25:05 PM »
are the #'s correct for a '77 K ?.....wonder what the frame # actually is...
that's an "F" front fender....
« Last Edit: January 12, 2023, 05:31:50 PM by jlh3rd »
Offline jpdevol
« Reply #66 on: January 12, 2023, 09:56:56 PM »
'76 750A
The part number you showed is 50356-393-010 for the Right Rear Engine hanger (item 8 from the fiche), the part number of the “BRKT C. FR ENG HGR” (item 7 on fiche) is 50351-393-000
« Reply #67 on: January 13, 2023, 12:59:27 AM »
Based on what?
Offline jlh3rd
« Reply #68 on: January 13, 2023, 04:28:11 AM »
no front stay....either that or its missing...
Offline jlh3rd
« Reply #69 on: January 13, 2023, 04:35:17 AM »
'76 750A
clicked on wrong one...ok....but...
#7 is still not it.....it is ONE -SIDED.....can't you see that?
.....again...
« Last Edit: January 13, 2023, 05:02:19 AM by jlh3rd »
Offline jlh3rd
« Reply #70 on: January 13, 2023, 04:44:47 AM »
Based on what?
It didn't have the front stay....but, nevermind, starting in 1977 for the K's , they went to a single stay....
« Reply #71 on: January 13, 2023, 04:45:43 AM »
Both the 1977 (right) and 1978 (left) cb750K fenders had the single stay (no front) fenders.
« Last Edit: January 13, 2023, 04:47:40 AM by BenelliSEI »
Offline jlh3rd
« Reply #72 on: January 13, 2023, 04:49:38 AM »
yep...I corrected myself...of course,they started that in'77 for the  K's.....I should never assume.....
« Last Edit: January 13, 2023, 04:51:31 AM by jlh3rd »
Offline beemerbum
« Reply #73 on: January 13, 2023, 08:11:11 AM »
For what its worth, my 1977 K7 750 has 9/76 build date. It has the "no number" engine mount
« Last Edit: January 13, 2023, 08:13:05 AM by beemerbum »
Offline jlh3rd
« Reply #74 on: January 13, 2023, 08:43:57 AM »
10/76, 9/77, 12/77.......bung
8/76, 9/76, 3/77.....bracket.....
« Last Edit: January 17, 2023, 02:43:31 PM by jlh3rd »
