« Reply #12 on: January 13, 2023, 01:19:51 AM »
On the box are the sizes the tubes can be used with. I'll put a conversion table under here.
So that means that my front 3.50" rim that I have my 130/70-18 wheel to go with - this tube won't fit?
Same with my 4.25" rear with my 150/70-18 wheel.
So I have to get a tube that specifically states 3.5 and fits 130/70-18?
You need a tube to fit your tire size, not the rim size. You need a tube to fit 130/70-18 if that is your tire size.
What's the point then? Isn't there a minimum and maximum tire size that can mount to certain rim sizes? So why not just state that? It's so confusing.
Edit: I just spent 10.mins looking and I can't find a tube for my 130/70-18 that corresponds to a 3.50" rim. Same with the rear. The 150s are saying rim size of 6"+.
They never use the rim size to determine the tube usage.
Tubes are marked for the tire size they are designed for only.
Only tires are designed to fit a rim width.
![](http://forums.sohc4.net/Themes/default/images/ip.gif)
Logged
