Author Topic: Is my side stand mount bent?  (Read 977 times)
Offline danpartipilo
« on: January 12, 2023, 02:24:00 PM »
I never checked my side stand mount before powder coating my frame and I'm afraid my frame tab is bent.  Can someone confirm?
Re: Is my side stand mount bent?
« Reply #1 on: January 12, 2023, 02:24:33 PM »
Pic 1
« Reply #2 on: January 12, 2023, 02:25:34 PM »
Pic 2
« Reply #3 on: January 12, 2023, 02:26:27 PM »
Pic 3
« Reply #4 on: January 12, 2023, 03:11:06 PM »
 It's hard to tell, you can bend the sidestand to suit as long as you make sure it folds properly. sometimes the early bike frames corroded inside and the tube failed, then during the repair it didn't get angled right. At least that's what happened with mine.
« Reply #5 on: January 12, 2023, 03:49:59 PM »
Thanks.  My frame is solid.  I just wasn't sure about the mounting tab with the hole for the bolt.  I'm not sure if that's supposed to be like that from the factory of if it is indeed bent from old age.
Offline BenelliSEI
  • 1969 cb750
« Reply #6 on: January 12, 2023, 03:53:49 PM »
The centre plate is usually flat......
Offline newday777
« Reply #7 on: January 12, 2023, 03:56:04 PM »
+1
Stu
My current rides
Prior bikes....
« Reply #8 on: January 13, 2023, 09:15:15 AM »
  OK, I see it now. Maybe you could use a large crescent wrench and stay in the wear area where the side stand goes.  They do take a beating.
Offline newday777
« Reply #9 on: January 13, 2023, 11:08:11 AM »
Definitely needs to be flat
Stu
My current rides
Prior bikes....
Offline grcamna2
« Reply #10 on: January 13, 2023, 01:13:39 PM »
Lean the bike over on it's right side,then use a Big Crescent wrench to straighten it,done.
75' CB400F/'bunch o' parts'
Offline Shtonecb500
    • Youtube profile
« Reply #11 on: January 13, 2023, 01:15:02 PM »
use a piece of rubber, scrap inner tube, inside the jaws of the wrench so u dont hurt powder...ya its bent.
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
« Reply #12 on: January 16, 2023, 12:42:24 PM »
Awesome, thanks for the replies!
Offline Airborne 82nd
« Reply #13 on: January 16, 2023, 06:51:05 PM »
How does the bike lean with the stand mounted. Has the po bent the side stand to compensate?
