Author Topic: Honda chain guard  (Read 1550 times)
Offline Johnie
Honda chain guard
« on: January 12, 2023, 03:04:11 PM »
I got a box of Honda parts at an auction and can't ID this chain guard. Any ideas out there? THX
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Re: Honda chain guard
« Reply #1 on: January 12, 2023, 04:10:17 PM »
Possibly a Honda Dream
« Reply #2 on: January 12, 2023, 05:55:57 PM »
Honda C70 Passport...got any measurements?
Offline Johnie
« Reply #3 on: January 12, 2023, 07:05:53 PM »
From the horseshoe cut to end 17". Overall 21 1/2". Top to bottom 9".
Oshkosh, WI  USA
« Reply #4 on: January 12, 2023, 10:28:05 PM »
I checked with a friend who works on Honda CA77/78 305 Dreams and owns a few of them;he checked and says this is a chain guard(right side chain drive)for those bikes.
« Last Edit: January 12, 2023, 11:58:58 PM by grcamna2 »
« Reply #5 on: January 12, 2023, 11:30:18 PM »
Likely the CA77/78 as too big to be a C70 with those dimensions...
« Reply #6 on: January 13, 2023, 12:02:29 AM »
Correct,plus the 1981' Honda C70 has a traditional left side drive chain case/guard.
Offline Johnie
« Reply #7 on: January 13, 2023, 10:47:27 AM »
Good info guys thanks. I'll go with the CA77/78 305 Dreams...right side chains. I'm sure someone is probably looking for one.
Oshkosh, WI  USA
Offline jgger
« Reply #8 on: January 13, 2023, 11:22:00 AM »
FarceBook has a pretty active 250/305 group that might be interested. There alot of CA /Dream guys there. That is one bike that I could never understand the attraction to.
« Reply #9 on: January 13, 2023, 11:24:57 AM »
I've wanted a bike with one of those fully enclosed chain case/guards for a while:they make your chain last a long time.
I realize though that they're proprietary to each bike they came on;can't be swapped unless you do quite a few mods.
Offline Alan F.
« Reply #10 on: January 13, 2023, 01:42:25 PM »
I've toyed with the idea too, maybe someday on a project bike.
« Reply #11 on: February 27, 2023, 06:30:33 PM »
Does anyone here have one of those cast aluminum chain housings for the CB750 with the 2 rubber accordion-style boots that connected to the cast-aluminum housing over the drive sprocket - which mounted to the 2 screw holes on the engine in place of the sprocket cover - and into which you poured 8 ounces of SAE 90w inside, to lube the chain?
They cost $119.98 in 1980 and we all the rage around here for the 750, but I haven't seen one in years. The guys I know who had them said they didn't adjust their chains but once per year with constant riding. They weighed about 6 lbs.
« Reply #12 on: February 27, 2023, 07:37:13 PM »
I think that's a very nice OEM option.
« Reply #13 on: February 27, 2023, 07:40:29 PM »
Shortly after I joined the forum I remember advertising one of those set-ups you are describing Mark that came off a K2 I had bought. I remember Ricky Racer out in California buying it and him kind of laughing as to why in the heck he was.  We all know he has some cool stuff around. Wonder if he still has it kicking around. That chain was quite minty looking on that bike when removed.
  I'll have to take a look on my other computer and see if I have a picture of it mounted up.
« Last Edit: February 27, 2023, 07:42:13 PM by ekpent »
Offline Johnie
« Reply #14 on: February 28, 2023, 06:40:52 AM »
At the auction I got a NOS CB750 chain guard housing still in the box. Looks like the one I've seen on some KO's when people had trouble with the oil splash from the chain oiler. I will post up a pic soon.
Oshkosh, WI  USA
Offline Johnie
« Reply #15 on: March 01, 2023, 12:25:20 PM »
Pics as promised…
« Last Edit: March 01, 2023, 12:28:31 PM by Johnie »
Oshkosh, WI  USA
« Reply #16 on: March 01, 2023, 02:15:34 PM »
I think I put something like that on my 750 back in the day. I also tried an aluminum sprocket in back as well as a plastic one. None of it worked very well.
Offline C317414
« Reply #17 on: March 01, 2023, 03:50:51 PM »
I remember the nylon sprockets.  I was a motorcycle accessories sales rep in the mid-70s and one of the companies I represented was Jacwal.    They made kits that included a steel front sprocket, nylon rear sprocket, and a chain.
« Reply #18 on: March 01, 2023, 05:01:07 PM »
Pics as promised…
I like that Johnie,it looks like it will use the OEM stock chainguard together with that as the lower section.
Offline Johnie
« Reply #19 on: March 01, 2023, 05:12:09 PM »
Not sure if it was for top or bottom? Didn't look at it to close. I figure it was for the top since that was where most of the oil would sling off. I'll have to take a look.
Oshkosh, WI  USA
« Reply #20 on: March 01, 2023, 07:05:19 PM »
The pic makes me think that's the bottom? and it matches-up to the stock OEM standard upper chain guard?
Online Don R
« Reply #21 on: March 02, 2023, 08:04:48 AM »
 I had a bike with the 360* plastic chain guard with the little oil bottle on top. I should have kept it, I also had one with the nylon rear sprocket. If I had been a farmer there would be a barn full of those old bikes by now.
Offline Johnie
« Reply #22 on: March 03, 2023, 07:58:51 AM »
Here's a pic when I brought my first KO project home. Only 18,000 miles on it. Check out that chain guard. I think grcamna is correct. What I have here in a box is the bottom which mates to the OEM plastic guard.
« Last Edit: March 03, 2023, 08:05:22 AM by Johnie »
Oshkosh, WI  USA
« Reply #23 on: March 03, 2023, 08:59:01 AM »
I like that Johnie;it would be great to be able to find one.
Offline Johnie
« Reply #24 on: March 04, 2023, 06:46:27 AM »
We do keep looking don't we...
Oshkosh, WI  USA
