Author Topic: K0 oil jets  (Read 622 times)
K0 oil jets
« on: January 18, 2023, 03:29:43 PM »
What do you do with them?
Just clean and leave them where they are?   I made quite few jets for later engines, I could make a replacements to fit the K0 head.
Re: K0 oil jets
« Reply #1 on: January 18, 2023, 04:37:55 PM »
Is the head on the bench and does it have removable jets or just drilled holes.
Re: K0 oil jets
« Reply #2 on: January 18, 2023, 05:05:39 PM »
The head is on the bench and there are what looks like removable jets but they do not budge to finger efforts.
Re: K0 oil jets
« Reply #3 on: January 18, 2023, 05:25:30 PM »
The head looks - as far as oil jets go - just like this CMSNL diagram.
Offline BenelliSEI
  • 1969 cb750
Re: K0 oil jets
« Reply #4 on: January 18, 2023, 05:53:55 PM »
Careful. Some my earlier heads do not have removable jets. Some just had an alloy slug driven into the hole (from the top) and then an angled hole drilled at about 45 degrees, over into the stud hole. If that’s what you’re looking at, just run a fine wire through and then blow through with brakekleen (using the straw extension).
Re: K0 oil jets
« Reply #5 on: January 18, 2023, 06:18:39 PM »
Thank you.  That's what this looks like.
Offline BenelliSEI
  • 1969 cb750
Re: K0 oil jets
« Reply #6 on: January 19, 2023, 07:13:22 AM »
Found the photo! Zoom in on the closest one and you can see it clearly. Cheers, John D.
« Last Edit: January 19, 2023, 07:15:21 AM by BenelliSEI »
Re: K0 oil jets
« Reply #7 on: January 19, 2023, 07:38:27 AM »
Thank you.  Yes, thats what I have.
