Author Topic: Flange Driven Seal  (Read 422 times)
Offline Ellz10
  • ZZ
  • Knowledge is Power
Flange Driven Seal
« on: January 21, 2023, 09:08:27 AM »
Another seemingly clueless question... - Do I need to put grease inside this seal that is then attached to the flange?
Thankful for everyone on this forum. Grateful to continue to learn so much.
'77 K7 - http://forums.sohc4.net/index.php/topic,193043.msg2251436/topicseen.html#new
Offline Bodi
Re: Flange Driven Seal
« Reply #1 on: January 21, 2023, 09:14:01 AM »
Seals should always be lubed. Oil on ones keeping oil inside, grease if greased inside. But it looks like the hub will be empty, so I would lube it with grease, packing the cavity as well as on the lip.
Offline Ellz10
  • ZZ
« Reply #2 on: January 21, 2023, 10:13:40 AM »
Okay awesome! I wasn't going to but thought I'd ask because it couldn't hurt and only help. Thank you!
