Author Topic: '81 CB650 Inner front brake pad always touching rotor  (Read 382 times)
Offline verro
« on: January 21, 2023, 07:01:27 PM »
Hey! I have always had this problem since I got the bike. I thought it was a bad piston but after rebuilding the brake I see that is not the case.
I couldn't get a better picture because the wheel was obstructing, but the right brake pad did not have any room to move. The left one has plenty of room. I can still roll the bike around but there is an annoying resistance. I followed the schematic of the brake and I have all the pieces and it is assembled correctly. Does anyone know what the problem could be? Thanks for your help!
1981 CB650
Re: '81 CB650 Inner front brake pad always touching rotor
« Reply #1 on: January 21, 2023, 07:49:32 PM »
These days, it is not unusual to get some generic parts (like brake pads) that are not quite umm... exacting about adhering to Honda's 50-year-old specifications. This situation [edit] appears to me [/edit] to be one of those. The brake caliper, if it does not have a spacer screw for adjusting the non-moving pad's clearance from the rotor, will have to simply wear in the stationary pad to the minimum nominal clearance. This happens sometimes with the CB750F0/1 rear caliper: it has happened to me twice.
The OEM spec for the pad-to-rotor clearance for the non-powered pad is 0.1mm/0.004", if you have an adjuster for it. I usually set them a bit tighter, like 0.05mm/0.002" instead, as many of the rotors are not dead flat anymore, and this tighter adjustment will reduce the free-play in the brake lever.
I have had to 'reduce' the thickness of several brands of the pads (static pad side) in the past.
« Last Edit: January 22, 2023, 07:48:03 PM by HondaMan »
« Reply #2 on: January 21, 2023, 09:45:15 PM »
The pads are NOT installed correctly. The back of the inner pad should be sitting flat against the caliper body; there is a visible gap in the pic. The shinny spring plate thingy on the outer pad is upside-down; those tabs should be between the pad backing plate and the inside of the caliper body.(EDIT I need to verify the part about the spring plate orientation. In any case, it is the same for both pads.)
« Last Edit: January 21, 2023, 09:50:50 PM by scottly »
Offline verro
« Reply #3 on: January 22, 2023, 06:21:22 AM »
There is no gap between the pad and the wall, or else i wouldn’t be having this issue. I also have installed the spring plate correctly, according to this:
1981 CB650
Offline verro
« Reply #4 on: January 26, 2023, 09:46:37 AM »
Thanks for the help, and that's exactly what I did. Put them on the belt sander until they were a good width, worked like a charm. I had this in my mind but didn't know if it was something I should do. But the brakes work perfectly fine now. Thanks :)
1981 CB650
