AGM battery has different needs. Google on it.
Charging voltage needs to be higher, 14.8V.
When charging in garage, charge until full, 24 hours or so.
Not low charge during a long period of time.
Chargers have AGM mode which is same as snowflake setting, higher voltage when cold for std batteries outdoors.
I have often got thoughts about std "wet" batteries as best choice for our CB's without modifying more charging related.
I have tested GEL (need lower charge voltage), latest was AGM.
I'll see how long time it will survive.
I think the old style will be next. Probably a maintenance free without refill caps.
