Author Topic: Cool Tools.  (Read 41043 times)
Offline Kelly E
  • Geriatric Hooligan
Re: Cool Tools.
« Reply #200 on: February 16, 2024, 07:43:30 PM »
Somebody else mentioned JIS screw driver in this thread. I'm a 67 year old backyard mechanic and never heard of this until 2 years ago. As soon as I heard about it, a light bulb went off in my head. I always noticed how difficult it was to screw and unscrew Phillips head screws on Japanese motorcycles, never realizing that they weren't Phillips head. No pictures but I immediately bought a set (2 sizes) off Amazon. They work great. who knew.
Yep, we got our JIS screwdrivers a few years ago. The difference is amazing. I ran into a similar thing back when I got my MGB. They use Pozidrive screws which work as well or better than JIS screws.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline Gurp
  • I'm no.......
  • Once was a...
Re: Cool Tools.
« Reply #201 on: February 17, 2024, 11:06:36 AM »
They are great.
At work we have a lot of pozi-drive screws in equipment. It's a hassle.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
Offline Kelly E
Re: Cool Tools.
« Reply #202 on: February 17, 2024, 04:17:00 PM »
They are great.
Do they supply you with regular phillips head screwdrivers or something?
1983 Honda CB 1100F
Offline Gurp
  • I'm no.......
  • Once was a...
Re: Cool Tools.
« Reply #203 on: February 17, 2024, 05:27:50 PM »
They have some pozi-drive bits but with the variety of machinery we have you never know when a repair will contain iso(absorbed JIS) pozi or reg Phillips cross head in the contactors.
Offline Kelly E
Re: Cool Tools.
« Reply #204 on: February 17, 2024, 06:44:56 PM »
Sounds fun, always carry 3 times what you should have to. ::)
It's like working on both of my trucks, part standard and part metric.
1983 Honda CB 1100F
Offline gearsoup
  • Maine, USA
Re: Cool Tools.
« Reply #205 on: February 18, 2024, 03:39:05 AM »
Does anyone have a link to a good set of feeler gauges for valve clearance adjusting on the CB750K? I like the MotionPro units, but they certainly aren't cheap. I'm thinking about buying individual feeler stock and just bending them. Thoughts?
Current Project: CB750-K6 (hoping for OEM look)
Future Project: CB750-K8  (likely go wild on this build)
Offline Gurp
  • I'm no.......
  • Once was a...
Re: Cool Tools.
« Reply #206 on: February 18, 2024, 06:03:51 AM »
Late 90s GM products?
They were bad for it haha.
My Sportster was bad for it when I got it. Wrong bolts forced into holes. So many hole re-tapped and enlarged to the next size.....
Re: Cool Tools.
« Reply #207 on: February 18, 2024, 06:24:20 AM »
I have and like the Starret and mitutoyo tapered feeler gauges best…
I have a cheap set of Craftsman’s tapered and 45 degree bend feeler qauges that catch everything else. Especially when you need to bend or straighten a bit to get that perfect access…
https://www.amazon.com/Starrett-66T-Thickness-Tapered-0-0015-0-025/dp/B0006J4DJO
Starret has single gauge stock as well…
Re: Cool Tools.
« Reply #208 on: February 18, 2024, 11:22:14 AM »
I just got a 2nd set.
.002-.015" thin 1/4" wide by 4" long very flexible.
They fit Japanese motorcycle valves better than the wide automotive type feeler gauges. About $20 shipped.
Re: Cool Tools.
« Reply #209 on: February 22, 2024, 12:49:22 PM »
Working on carbs today, using my smaller ultra sonic tank (I do them one at a time so everything goes back in its original spot). My wife got me a few of these stainless “tea caddies” for the tank. Normally used for loose tea, in a large pot. They’re perfect for collecting all the jets, tubes, float valves, etc., and suspending them in the tank. Cheap Dollar Store items.
Offline Gurp
  • I'm no.......
  • Once was a...
Re: Cool Tools.
« Reply #210 on: February 22, 2024, 01:17:38 PM »
That's pretty slick!
Re: Cool Tools.
« Reply #211 on: February 23, 2024, 12:10:02 AM »
and you can make a gallon of ultrasonic tea if you want!
Re: Cool Tools.
« Reply #212 on: February 23, 2024, 06:42:05 AM »
Not sure my tank will get the water hot enough?!
Re: Cool Tools.
« Reply #213 on: February 25, 2024, 09:13:49 AM »
Found this with my dad's  threading tools.  He used it to measure the pitch.
Offline Bankerdanny
  • Endeavor to persevere
Re: Cool Tools.
« Reply #214 on: February 26, 2024, 03:26:23 PM »
Today I used this MAC tool kit my son gave me. One of my wife’s broken appliances (melted wire where, it joined a spade connector) was held together with Philips screws than have only THREE slots..... WTF is that all about? Looked through the box and there’s was a full set X four sizes of these weird bits!
Very handy set.
I have a set of torx bits with a hole in the middle.  I had to buy them for some work on Volvo.  Torx heads should not exist, imho, this was just another level of beef I have with them.   ;D
There is a 3rd style of Torx bit, Torx Plus. GM used them to attach bellhousings to transmissions. The stars have flat points. It's like the JIS screws, a regular torx might work, or it might strip out the bit. I had to search around to find a set to pull the bellhousing off my 4L60E in my Envoy. I finally found a set at Northern Tool that included the right size bit that was not outrageously expensive.
Re: Cool Tools.
« Reply #215 on: March 06, 2024, 05:18:49 PM »
Took a piece of 1/4-20 threaded rod and double nutted a rubber covered tube clamp to the top. Covered the end with a rubber cap. The other end goes through the mirror hole in the left bar switch. Two washers and two 14-20 nuts and it’s tight. In addition to the remote fuel tank, I can also hang up my Motion Pro synchronizing board. No more dropping them from the left side grip!
Re: Cool Tools.
« Reply #216 on: March 06, 2024, 06:26:16 PM »
I was wondering how you had attached the "stand" in the bike build thread. Very cool.
Re: Cool Tools.
« Reply #217 on: March 06, 2024, 06:37:02 PM »
I stopped by to visit with a friend yesterday who I've helped out doing trike conversions on Goldwings and Vaukyries in San Diego. He says come check out these new Allen drivers from Mac Tools. They have teeth to grab stripped socket heads where a standard Allen wrench/socket would just spin around. They are available in Metric and SAE standard sizes. A very cool tool, only available through Mac Tools. They are the Bee's knees!
Re: Cool Tools.
« Reply #218 on: March 06, 2024, 06:48:23 PM »
The Mac Allen Sockets come in different drive sizes and bit lengths. Not for the faint of heart.....
This is the 1/4" drive set but if you look through the catalog you can buy just the individual sizes you want.
https://www.mactools.com/products/smh17rbrt
Re: Cool Tools.
« Reply #219 on: March 06, 2024, 08:52:05 PM »
The picture is too dark
Re: Cool Tools.
« Reply #220 on: March 06, 2024, 09:29:01 PM »
I agree but it is what it is. I'm not techie enough to fix it.
If you enlarge the picture it helps.
Offline jgger
Re: Cool Tools.
« Reply #221 on: March 06, 2024, 10:06:43 PM »
There ya go Stu. I love the Mac Tools I have, but yeah, they ain't cheap.
« Last Edit: March 06, 2024, 10:09:27 PM by jgger »
Re: Cool Tools.
« Reply #222 on: March 09, 2024, 08:54:47 AM »
My ancient Motion Pro Sync. tool. Cleaned out and reloaded today. I like the way you calibrate it each time. Hook it up to one cylinder (all four columns) and ensure they are all identical, on the day. Very reliable. The only thing you have to watch is NOT to create enough vacuum to suck the fluid out the top.
Re: Cool Tools.
« Reply #223 on: March 10, 2024, 10:06:18 AM »
Yeah, I have the same one. Has served me well.
Re: Cool Tools.
« Reply #224 on: March 10, 2024, 03:43:09 PM »
What did you fill it up with?
