Author Topic: Cool Tools.  (Read 91529 times)
Re: Cool Tools.
« Reply #250 on: April 12, 2024, 10:20:35 PM »
Hey HondaMan,i have a couple of indestro chicago short flat imperial ring spanners.
Re: Cool Tools.
« Reply #251 on: April 13, 2024, 12:03:24 AM »
Proto is that snap on consumer grade or another brands consumer version?
Offline simon#42
  • liverpool
Re: Cool Tools.
« Reply #252 on: April 13, 2024, 03:46:06 AM »
no blue point is the snap on cheaper brand . proto is a separate firm , i have some proto tools and they are very good .
Re: Cool Tools.
« Reply #253 on: April 14, 2024, 12:31:01 AM »
Williams, that’s the other company name I was trying to recall
Re: Cool Tools.
« Reply #254 on: April 16, 2024, 02:47:25 AM »
Why do you need an offset handle tap wrench, For what is it used, or does it help overcome?
Several times I had to improvise with tap handle when there was not enough room to rotate it.
Re: Cool Tools.
« Reply #255 on: April 16, 2024, 05:49:48 AM »
Build your own cleaning tank?
Here's an idea a buddy shared with me, years ago, when I built my own tank. It’s a stainless (hospital size) sink, cut into one end of a 2’ X 8’ woden bench. A 5 gallon bucket  is hung below. Pardon the lousy drawing, but hopefully a picture is worth a thousand words! We use varsol in this tank, so it sits on top of the 1-2 gallons of water in the tank bottom.
The trick is to get the drain pipe deep in the water, so the varsol bubbles up slowly and drops all the real crud  falls to the bottom. When the drain gets plugged, it’s time to scrape out the bottom of the barrel!
« Last Edit: April 16, 2024, 05:57:47 AM by BenelliSEI »
Re: Cool Tools.
« Reply #256 on: April 16, 2024, 09:36:09 AM »
How about a ratcheting spanner box wrench that will fit over the square end of the tap?
Re: Cool Tools.
« Reply #257 on: April 16, 2024, 11:33:52 AM »
That was the original manufacturer “JH Williams”. They originally made snap on too.
Snap On acquired Williams and eventually changed the name later.
Re: Cool Tools.
« Reply #258 on: April 16, 2024, 03:08:38 PM »
Spotty and I cleaned the injectors on my BMW K100RS on the weekend. I love gadgets so bought a little $40 heated ultrasonic heater and injector tester ($36, from memory) and I brought over the Vevor injector cleaning kit with compressed air regulated feed tank.
We sat the injectors in the little ultrasonic cleaner all day in a mix of auto paint degreaser (very mild thinner that doesn’t affect O rings) with a few drops of injector cleaner. Once we’d finished un-clogging the hard brake lines down to the ABS modules and back to the calipers (9 years of sitting had caused rusty clumps to block all of the lines) flushed and bled them, we returned to the injectors.
The little ultrasonic cleaner had done a brilliant job and the fluid in the little tank was black with lots of little chunks of crap floating around. The inbuilt heater was a real bonus as it really helped to dissolve the muck. We pulled them out and dried them off, then connected the Vevor tank with pressure set at 15 psi to each injector, hooked up the test unit and was able to “pulse” each injector to ensure that the solenoids were working correctly.
I’m glad I bought these “cool tools”, a couple of years ago I replaced the injectors in my little Mitsubishi truck, which cost $400 and didn’t fix the problem, and so from now on I can clean and test injectors before replacing them, and all up, the tools were less than half the price of the Mitsubishi injectors. ;D
Re: Cool Tools.
« Reply #259 on: April 16, 2024, 05:31:07 PM »
Very good to have Terry.
Re: Cool Tools.
« Reply #260 on: April 16, 2024, 06:38:27 PM »
Thanks Bill, I watched some Youtube videos of guys doing the same thing with just a battery and a spray can of carb cleaner etc, but I do love gadgets and with Amazon being so quick to deliver, I had to buy them.
Spotty very kindly gave me a new front fender for my DT250 so I gave him the little ultrasonic cleaner, then ordered another one when I got home, as it’s just the right size for cleaning carb parts etc, which would disappear in my 30 litre ultrasonic cleaner. ;D
Re: Cool Tools.
« Reply #261 on: April 16, 2024, 06:44:34 PM »
  In the center is my Dad's old Craftsman palm ratchet, it came with matching screwdrivers that had the square hole in the end also. The bottom right is the manual brake adjuster for my trailer wheels I blacksmith'd that. The spark plug starter is mandatory on a cb750.
« Last Edit: April 16, 2024, 06:46:38 PM by Don R »
Re: Cool Tools.
« Reply #262 on: April 17, 2024, 05:29:48 AM »
Don…..I have a”Spark Plug Starter” that looks just like that!!
Re: Cool Tools.
« Reply #263 on: April 18, 2024, 06:47:55 AM »
My new belt grinder. Bought it on ebay from Poland.  It shipped for $68, got it in a.week. Motor is 2hp  Vevor.  It fits my needs well.
Major US ebay seller ships from California for $216 - something I do not understand.
Offline simon#42
  • liverpool
Re: Cool Tools.
« Reply #264 on: April 18, 2024, 10:57:54 AM »
thats a serious looking piece of kit
Re: Cool Tools.
« Reply #265 on: April 19, 2024, 02:43:37 AM »
It grinds flat in this setup, but you can have a contact wheel for grinding convex shapes.  It can be accesorized, sky is the limit, for knife makers.
But I use it now to fit a seat bridge back on the frame of Dorothy.  The PO cut it off and bondoed the crap out of the frame.
Re: Cool Tools.
« Reply #266 on: April 19, 2024, 03:53:38 AM »
Prokop, who was the seller on eBay...
Friend is into knife making
Re: Cool Tools.
« Reply #267 on: April 19, 2024, 06:43:56 AM »
Re: Cool Tools.
« Reply #268 on: April 22, 2024, 09:13:53 AM »
 I went shopping for a set of universal tools for my non-Honda, on my list is a metric dogbone wrench, a 4-1 screwdriver, a small Crescent wrench with the fat handle and big head, small pliers of some sort, I like the small channel locks but want a wire cutter also. Any other trick ideas?
Re: Cool Tools.
« Reply #269 on: April 22, 2024, 07:55:54 PM »
I like these cheapo 1/4” drive metric socket sets. I carry one in my tank bag. Not for everyday use, but great in a pinch.
Re: Cool Tools.
« Reply #270 on: April 25, 2024, 02:29:54 AM »
This popped up on Facebook.
Re: Cool Tools.
« Reply #271 on: April 26, 2024, 05:55:09 PM »
I needed to join some very thin wires yesterday. My regular wire strippers were too big, so I kept trawling thru my various tool collections, and found my old "Gedore" (German) strippers, which of course, worked perfectly. Much nicer than the cheapo Chinese knockoffs. ;D
K100RS Friday 26 April 2024 7 by Terry Prendergast, on Flickr
Offline britman
Re: Cool Tools.
« Reply #272 on: May 20, 2024, 10:16:30 AM »
You know that tool you say I got to get one these when you need like once every two years, well the time has come.  I had to make a homemade gasket for a timing chain adjuster a few days ago, mainly because I wanted to finish adjusting valve lash and didn't want to wait at least a week for one to arrive from a vendor. With the X-acto knife and a single edge razor blade I had one done in just a few minutes since the old gasket was torn but still intact enough to make a decent template.  When I got to the holes I had to use a flat nose punch and the knife to get them fairly clean.  That will not happen again thanks to Amazon.  The gasket/leather hole punch set arrived the next day, so the next time this happens I am ready.  One of those sets that will live in the bottom of the tool chest in bear like hibernation, but will rise to the occasion when called for.......
Offline Kelly E
  • Geriatric Hooligan
Re: Cool Tools.
« Reply #273 on: May 20, 2024, 10:44:01 AM »
I have a set of those, it turned out that I use them so much I've had to sharpen a couple of them.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Re: Cool Tools.
« Reply #274 on: May 26, 2024, 01:41:35 PM »
Me too Kelly, they’re a great tool but blunt pretty quickly. ;D
